-   -   Casita Battery Charger mods for adding a AGM battery? (https://www.fiberglassrv.com/forums/f95/casita-battery-charger-mods-for-adding-a-agm-battery-88150.html)
doctoruv 02-13-2019 02:57 PM
I am looking at adding a AGM style battery to replace the standard Lead Acid battery. What changes will I have to do to my 2005 Casita Spirit Deluxe battery charging circuit to maintain the AGM battery?
Doctoruv
patrick crawford 02-14-2019 08:07 AM
my casita has an upgrade progressive dynamics 12v portion of the converter. no modification needed to work with 2 6v agm golf cart batteries. i did have to modify the 2 morningstar solar controllers as per morningstar's suggestion. i used the provided bridge gizmos (technical term) to eliminate the float stage (i think). in case you can't tell, i'm certainly no electrician but all seems to work well.
p@
Stephen_Albers 02-14-2019 01:51 PM
For a simple fix, no changes are needed. For a comprehensive one, remanufacturing the inadequate electrical system is needed.
