-   -   New genset ? Westinghouse iGen4500DF $1100+/- (https://www.fiberglassrv.com/forums/f95/new-genset-westinghouse-igen4500df-1100-a-88333.html)
Al and Cindy K 02-27-2019 07:39 AM
I hadn't run across this model until today. Looks like a lot of features for the price. Anyone with experience?
Dual fuel (propane or gas)
Gas - 3700 watts continuous / 4500 watts peak
Propane - 3330 watts continuous / 4050 watts peak
Inverter technology
Electric start
Remote start
52 db (did not specify distance or engine load)
Two 20A, one RV 30A, two USB plugs
3.4 gal fuel tank, 18 hrs run time on gas @ 1/4 load
Three year warranty
98 lbs
Wheel kit
List $1149 Available @ lower price from Amazon and several big box stores
https://www.westinghouseoutdoorpower...MaAqixEALw_wcB
gordon2 02-27-2019 08:12 AM
Its the ~100 pounds that concerns me.
A smaller Westinghouse gen has been discussed here a little:
https://www.fiberglassrv.com/forums/f...tor-80181.html
https://www.fiberglassrv.com/forums/f...tml#post727294
Mike255 02-27-2019 11:24 AM
Unless you need for AC, for $1150 I think you'd get more solar than you'd need. And less to go wrong. I seem to spend more time maintaining a gas motor than using it, at least that's my experience.
Glenn Baglo 02-27-2019 11:38 AM
I've got a couple portable solar panels ( total of 80 watts ) and now leave my Honda 1000 at home. I don't need a lot of power ( unless I use the furnace a lot ).
