-   Camp Cooking, Food & Recipes (https://www.fiberglassrv.com/forums/f58/)
-   -   Toast (https://www.fiberglassrv.com/forums/f58/toast-91960.html)
ThomasC 04-23-2020 09:43 PM
Toast
Does anyone have a way of making toast without the toaster. I could butter the bread and toast it on a frying pan but I'm hoping for a dry method. Now that I am typing this I realize I have never tried it with dry bread. Hmmm, I'll have to try tomorrow. Any other suggestions?
Iowa Dave 04-23-2020 10:00 PM
Get one of those fold up wire toasters for use over your camp stove burner. Once that base plate gets hot you can make nice toast. You have to flip it around as it toasts. Tongs would be appropriate but real campers would rather have the scars of the support wire burns on the tips of their thumb and index finger. It’s confirmation of membership in the fraternity of the stove top wire toaster brotherhood, the TSTWTB. I am not the oldest member but have been a member since 1960.
Iowa Dave
Iowa Dave 04-23-2020 10:08 PM
Iowa Dave’s wife says to me “hey rummy, tell the man to get a toaster oven and he can make pies too.” The burns and the lingering odor of a propane fueled fire that has permeated your toast are probably negatives.
But for only $3.99 you get the toaster and a membership in a fraternity.
Iowa Dave
ThomasC 04-23-2020 10:53 PM
Originally Posted by Iowa Dave (Post 775621)
Iowa Daveís wife says to me ďhey rummy, tell the man to get a toaster oven and he can make pies too.Ē The burns and the lingering odor of a propane fueled fire that has permeated your toast are probably negatives.
Iowa Dave
I have an oven in the new rig but I haven't tried it yet. That wire thing might be worth a try thanks.
AC0GV 04-23-2020 11:10 PM
Stove toaster
https://www.amazon.com/Coleman-20000.../dp/B00HNJS3FA
Lynn Eberhardt 04-23-2020 11:36 PM
We use the frying pan method. Non-stick pan, butter melted in, bread in and pushed around, bread flipped over = buttered toast. Use the same pan for eggs if you like.
Raz 04-24-2020 03:37 AM
2 Attachment(s)
Both types work well once you get the correct burner setting. I find the box type better if you only want one or two slices.
Attachment 134119Attachment 134120
Carl Pa 04-24-2020 03:56 AM
I have used and still have the wire toasting thingy for use in a pinch. But do not use the back burner,b/c you might burn/melt the window cranking plastic handle, do not ask how i know this.
Sid 04-24-2020 04:57 AM
1 Attachment(s)
This one works well for me. Folds flat for easy storage too!
Sid
ZachO 04-24-2020 08:15 AM
I use about the most inefficient toasted imaginable in a trailer - my oven. I'm lucky enough to have an oven, but that's what I use. I looked into those stove top toasters and I'm sure they do work once you learn how to use them, but they had very mixed reviews and my oven works great. But it burns a lot of propane just to toast bread...
ThomasC 04-24-2020 08:36 AM
I will have to try this. I'm going to have a solar setup that would make an electric toaster a no brainer but it is always good to have options.
Casita Greg 04-24-2020 08:54 AM
2 Attachment(s)
If you buy a simple toaster, then you've just bought a one-trick pony. Buy yourself a little toaster oven and you can do so much more with it. I have a Cuisinart toaster oven that pretty much does it all. I usually set it up outside on my home made wheel well table next to the outside convenience outlet. These things, even though they do take up some space, are really multi-tasking devices.
https://www.homedepot.com/p/Cuisinar...60N1/300864205
Jon in AZ 04-24-2020 09:20 AM
Is either really practical for off-grid use, even with solar?
Personally I donít like dry toast, and the frying pan works great for us and has many, many other uses!
Casita Greg 04-24-2020 09:23 AM
Who said anything about being practical. It's all about creature comforts. I gave up "roughing it" many years ago, just like sleeping on the ground in a tent. Just the way I roll. To each his own.
Jon in AZ 04-24-2020 09:35 AM
Not questioning your style of camping, Greg. My mother RVíd solo for 30 years and always had a site with power. You have plenty of good company.
Just questioning whether itís the right choice for someone that stated they were using solar, which usually means no hookups.
Given a large enough solar bank, lithium battery array, and a big inverter, a lot is possible nowadays. Including the most expensive piece of toast on the planet! :loltu
Jon Vermilye 04-24-2020 09:42 AM
Sid
I'ver used both stove top types, and, like Sid, prefer the Primus single slice type over the Coleman. That said, I far prefer a good old $10.00 pop up electric toaster running on my inverter.
tractors1 04-24-2020 10:17 AM
I found one Made in Canada instead of China that works well. https://www.amazon.com/Coghlans-504D..._t1_B00HNJS3FA
Glenn Baglo 04-24-2020 10:45 AM
1 Attachment(s)
Adapt. English muffins on the BBQ.
Raspy 04-24-2020 12:38 PM
This is the right answer! Thanks Greg.
Practicality has its place, but so do comfort and fun. I just added an
electric coffee maker to the trailer and it is the best addition I've done in a while.
Glenn Baglo 04-24-2020 01:47 PM
When you find that the wire toaster doesn't work for you, you can rip out the wires, discard them, and use the base as a simmer plate.
