Escape 5.0 or 5.0TA
I'm curious, is the Escape 5.0TA that much better than the 5.0? I've seen several of the 5.0TA's and a couple of the single axle 5.0's. Outside of the obvious Tandem axle vs the single axle what are the differences?
2 Attachment(s)
"much better" is subjective Steve. The TA, overall, is bigger (wider/taller) and the interior layout is very different in the kitchen area.
5.0 Kitchen on driver's side Attachment 134965 5.0TA Kitchen on passenger side Attachment 134966 |
How about the weight? Is the TA quite a bit heavier?
2 Attachment(s)
Attachment 134973 5.0ta Attachment 134974 |
Thanks Donna, looks like approx. 1200 lbs difference between the two.
I believe the TA has the big 2 door fridge did the original have the full size fridge?
1 Attachment(s)
This is the brochure for the 5.0 which will probably answer a bunch of your questions.
This is a link to the 2nd gen 5.0TA, it's too big, I can't upload it https://cdn2.hubspot.net/hubfs/54742...brochure-1.pdf
I can't upload the Classic 5.0TA brochure. It's too big. This trailer is like mine. Steve, if you want the brochure, PM me your email address.
Thank you very much Donna, can always count on you. I did see the inside of yours at one of the NOG's and it is beautiful. I have never seen the inside of the original 5.0.
The Classic 5.0TA, like mine, was built for 3 years. May 2014 to fall of 2017. Now the 2nd Gen trailers only. That information may help you if you're looking at used or want specific features only available with a specific build. :wave |
