-   -   Cadet pop top sky light (https://www.fiberglassrv.com/forums/f56/cadet-pop-top-sky-light-92597.html)
Cadet1986-MEg 06-18-2020 05:57 AM
1 Attachment(s)
Hi everyone!
I would like to switch out my cadet pop top for a clear skylight. It is about 3feet square. I was wondering if anyone has done it. I feel like I should be able to make a replacement top out of clear clastic or something?
Also wondering if there is an easy way to get more height by replacing the metal pieces?
Thanks for your insight!
Megan
PCO6 06-18-2020 10:30 AM
Megan;
That's an interesting idea and I don't see why you couldn't. I'm sure you could build a frame (wood properly sealed?) to match the contours of the original top and make the top of it out of Lexan, plexiglass or something similar.
As for getting additional height, I have an '86 Cadet too. It's currently a "project". I have all of the original top parts except for the mesh but I plan to secure the font leading edge of the top to the trailer with a hurricane hinge or something similar so that I can lift the rear of the top up to about 12". So rather than going straight up 4" or so only the back will lift but much higher. I'll have to make my own mesh (don't have one any way) and gas struts will help to lift it and also keep it up. This will allow in a lot more light and air. I have a tear drop trailer and the lid (much bigger!) lifts this way.
I like how you've done your front window. Do you have pics of it?
Stew
Cadet1986-MEg 06-18-2020 11:21 AM
Thanks Stew. I’ll look into those materials.
The hurricane hinge is a great idea. I’d love to see pucks of your Reno if you are sharing.
Meg
pvb1 06-18-2020 11:42 AM
I looked at doing something similar with your Trails West Campster when we were refurbing, if you look around their are a lot of commercially made acrylic skylights you could possible use.
In the end I didnt go that directly as I was worried about how to block early morning light and avoid the trailer becoming a greenhouse (California camping).
PCO6 06-18-2020 05:39 PM
Originally Posted by Cadet1986-MEg (Post 782229)
Thanks Stew. Ill look into those materials.
The hurricane hinge is a great idea. Id love to see pucks of your Reno if you are sharing.
Meg
I'm afraid mine's a slow moving project at this time as I'm finishing off 2 other trailer builds. The Jeep in this pic is also about to come apart. I'll be painting it and making it more overlanding friendly. I have lots to do and the Cadet is on the list!
https://www.garagejournal.com/forum/...ictureid=85369
Sennema 08-18-2020 10:33 AM
2 Attachment(s)
I raised my Cadet top. I used the same hinges, but put in longer bolts so that it goes up higher. I built my own sliding window inserts, and squared off the edges of the top and bottom so the windows would fit. Now if the rain is coming in, I can slide the windows shut.Attachment 136859Attachment 136860
