-   Care and Feeding of Molded Fiberglass Trailers (https://www.fiberglassrv.com/forums/f54/)
-   -   Scamp tail lights (https://www.fiberglassrv.com/forums/f54/scamp-tail-lights-95531.html)
mspgaff 04-28-2021 06:08 PM
Scamp tail lights
I know the old joke about how many people does it take to change a light bulb, but we could really use some ideas.
Issue: Taillight bulb blown. terminalsPurchased bulbs. the are apparently getting contact but still no light with new bulb An auxiliary set of lights installed ( at Backus) about 15 inches above the original set a couple of years ago and it went off once we got the old bulb out from the light with the initial problem. This issue is on only one side. Left side is in perfect working order. Your thoughts would be appreciated. Barb & John
AC0GV 04-28-2021 08:38 PM
Volt meter?
Have you had the volt meter out? Both tail and brake lights? If you are not getting the voltage on the bad one, use the working one as the negative contact for the meter as the problem could be the ground. Are you sure that the new lamp has two contacts (1157). It's also good to use tune up grease on the lamp base when changing them to keep the green stuff from forming.
Please let us know what you find.
Dan Meyer 04-28-2021 08:46 PM
Move the bulb from the other side to the non-working side.
Check fuses in the tow - mine has separate fuses for each turn signal and tail lamps for the trailer connector.
Give the connections in the storage area under the dinette seats a look. Pay close attention to splice in the green wire - this is the ground wire for all of the turn/brake/tail lamps. See your owners manual for a wiring diagram or look here: https://scamp.n0kfb.org/Manual/electrical.jpg
Good luck, and keep us posted!
--Dan Meyer :steer
Lockman 04-29-2021 11:40 AM
When you said "and it went off once we got the old bulb out from the light with the initial problem." did you mean that the upper bulb did not light when the bottom bulb was removed?
Sounds as if something was wired in series and that circuit was broken when the bulb was removed. I'd check the wiring with an ohm/volt meter to see if things are wired correctly. They should have or were suppose to wire them in parallel, at least I would have. I'd also check their connections where they wired in the new upper lamps.
Iowa Dave 04-29-2021 09:53 PM
Those grounds and the corrosion in the sockets can mess you up.
Iowa Dave
