-   -   Circuit breaker reset? (https://www.fiberglassrv.com/forums/f55/circuit-breaker-reset-95714.html)
roadfossil 05-16-2021 09:15 AM
Hello there:
New owner of a 2014 Lil Snoozy that I am working on, and have never saw a fuse? switch? panel like this before. What are the little "squeezable" bulbs for on the bottom of the panel? Where are the circuit breakers and how do you re-set them? Took off a wiring panel cover and saw some breaker-like square boxes, labeled with max amps, lying under a bunch of wiring, but they don't appear to have a re-set switch? Do these circuit breakers re-set by themselves when fault is cleared? Do I need to disconnect and remove bunches of wires to get at the circuit breaker re-set?
Thanks in advance......
AlanKilian 05-16-2021 09:51 AM
I've seen quite a bit of wiring, but not specifically Lil Snoozy wiring.
Can you post some photos showing what you are talking about?
Then I (or others who know more than I) might be able to help more.
Raspy 05-16-2021 12:48 PM
Originally Posted by roadfossil (Post 814321)
Hello there:
From your description, I'd say those are the resets for the circuit breakers. Not "squeezable" but made to push to reset. Your description matches what my trailer has.
roadfossil 05-19-2021 05:10 PM
Circuit breaker re-set
2 Attachment(s)
Here are a picture of the front and back of power distribution center, with cover removed from back to show wiring.Attachment 140982
Attachment 140983
Sorry about the rotation, still in learning phase on the site.
......Comments?
Don
Raspy 05-27-2021 12:07 PM
The toggle switches on the left with the amperage printed on them are marine circuit breakers. The rubber covered things on the right appear to be weatherproof switches.
