-   -   Fiberglass over cracked escape vent lid (https://www.fiberglassrv.com/forums/f55/fiberglass-over-cracked-escape-vent-lid-96634.html)
JEVanHorn 08-19-2021 04:46 AM
Hi all,
My 87 Scamp 13’ has an older style escape hatch with the piano hinge instead of the c channel that is on the scamp website. Unfortunately, I didn’t realize this until after the replacement part arrived. Luckily I can return the old one. I am hesitant to take on the project of removing the entire assembly and installing a new one at this time.
Would laying some fiberglass over the lid work? Will it adhere to the plastic? What kind of fiberglass do I use for such a project? I would obviously only be putting fiberglass on the lid itself to still be able to open it and get airflow in the the scamp.
Am I making this more difficult for myself and should I just suck it up and change out the whole unit?
Alex Adams 08-19-2021 06:10 AM
Try putting Flextape or similar product over the crack rather than fiberglass. I don't believe fiberglass would adhere properly to the plastic even if you rough up the surface. Just make sure to thoroughly clean the area. I used packing tape on my cracked vent lid and it lasted until I replaced it (2 years).
FRED SMAILES 08-19-2021 07:28 AM
Ya forget about fiberglass on plastic.
Id probably tape it up with something for the rest of the camping season then "suck it up" and change it.
Fred
kurtzinpa 08-19-2021 09:02 AM
Try it!
I bought a fibreglas kit at an auto parts store. My lchipper/shredder had a broken exit chute in 5 pieces and it worked fine. I used JB Weld epoxy (because I had it on hand). Brushed the JB onto the surface.
applied the fibreglas and coated it with JB. Since I could reach inside the chute I also applied the same to the inside. Cheap fix but it's been fine for three years.
Joy A 08-20-2021 05:24 PM
Exit vent lid cracked
Mine got hit by a tree limb, right through it this past Spring. First actual problem with my 2001 Scamp 13. It's 21 this Christmas, we are having a party.
All that being said, I taped it with Gorilla tape. Had minor leak I couldn't find but after this summers heat the glue must have seated better because no further leaks.
I am headed to the factory soon and was going to have them put a new lid on. We will see if they can because mine too has a piano hinge.
jwcolby123 08-20-2021 07:22 PM
Originally Posted by JEVanHorn (Post 822984)
Hi all,
My 87 Scamp 13’ has an older style escape hatch with the piano hinge instead of the c channel that is on the scamp website. Unfortunately, I didn’t realize this until after the replacement part arrived. Luckily I can return the old one. I am hesitant to take on the project of removing the entire assembly and installing a new one at this time....
Uh ohhhh.... Mine just broke and I ordered TWO of the new plastic ones, not the entire assembly:mad::(
parmm 08-20-2021 09:55 PM
You didn't fiberglass it, you JB welded it by glueing fiberglass to it. JB Weld is fantastic stuff. I used it to repair a water well pump that was cracked from being frozen. It would not hold prime. Saved a plumbing bill and the cost of a new well pump!!! That pump went on pumping for years.
Defenestrator 08-22-2021 12:11 AM
Fiberglass will probably work, but maybe not well and it's a lot of hassle. I'd say there's 3 feasible fixes:
Plastic-weld the lid. It's probably polycarbonate, but maybe the manufacturer says somewhere or will tell you. A bit tricky to do well in practice, but it'll seal well once done.
JB-weld or similar reinforced epoxy. Should stick well enough and hold. At least as well as fiberglass with a lot less difficulty.
High-sealing tape. Regular duct tape might work, but I'd lean more towards either something rubbery/soft like flextape, or something really strong like Eternabond.
Either way, like Alex said, prep is key. Get it cleaned off, then give it a wipe with acetone or isopropyl alcohol.
