1971 Boler Door Latch - Fiberglass RV
Old 11-10-2021, 12:59 PM   #1
Hello
My door latch no longer locks securely when locked. The latch still moves enough when the handle is moved to allow the door to open. It seems worn out.
Is it possible to replace the latch hardware or can it be repaired?
I don't want to drill out the rivets and remove until I have a plan or a replacement.
I would greatly appreciate any thoughts
K
kennyj is offline   Reply With Quote
Old 11-12-2021, 12:19 PM   #2
Trailer: Scamp 13
Massachusetts
Would not waste the time to try to repair a 50 yr old lock. Replace it yourself or have a locksmith do it. You should be able to find one on the internet.
Lockman is offline   Reply With Quote
Old 11-13-2021, 01:28 PM   #3
Mitten Mitsie's Avatar
Trailer: Trail Mite
https://smile.amazon.com/dp/B01347EM...v_ov_lig_dp_it
Mine is the same. Also riveted in. I noticed the holes that mount the outside piece do not match what I have. So this is an issue for me. But this is what I found on Amazon. Hope that helps.
Mitten Mitsie is offline   Reply With Quote
Old 11-13-2021, 01:28 PM   #4
Trailer: Trail Mite
Old 11-19-2021, 01:02 PM   #5
thanks. Will start looking.
Old 11-19-2021, 01:06 PM   #6
Thanks so much for your hèlp. The rv dealership suggested Amazon too. Wish i could support locally. Hate buying from Amazon but ...
Cheers
Old 11-27-2021, 12:54 PM   #7
I had a similar problem earlier this year. I drilled out the rivets and opened it up. There’s a spring inside that had broken in mine. It’s an odd oblong shape, but I picked up a pair of small regular springs at the hardware store and they’re working fine. I stuck them in place with a dab of JB Weld on one end, and the same in the rivet holes to hold the case back together. Not sure why I didn’t re-rivet it. Next time I’ll upgrade to a modern RV door latch, but this was an easy $2 fix.
toddq is offline   Reply With Quote
Old 12-19-2021, 09:17 PM   #8
Boler Lock replacement
You can get a kit at the link below to replace the original Boler lock with a a more modern one. I did this a few months ago and it worked really well. You need to confirm which original lock version you have as there are 2 types of kits. There are installation videos which you can see the process and types of locks it works with.
https://www.campingtreasures.com/pro...gory/hardware/
RobC is offline   Reply With Quote
boler
Need New Window - 1971 Boler 1971 13 FT varible154 Hi, I am.... 0 01-15-2021 09:16 PM
Boler Cabinet Door Catch / Latch Replacement Mike Roho Problem Solving | Owners Helping Owners 3 09-20-2020 12:44 PM
Boler Door Latch Doug Mager Classified Archives 0 08-08-2008 10:05 AM
Door handle and latch replacement for a '75 Boler KenReiss Problem Solving | Owners Helping Owners 9 07-15-2006 11:51 AM
