Escape hatch locations? - Fiberglass RV
Old 05-09-2013, 12:08 PM   #1
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'm curious about the type/location of secondary escape hatches or windows on various trailers.
On my '78 Trillium it's a swingout panel on the rear of the trailer.
What's yours?
Francesca
Old 05-09-2013, 12:22 PM   #2
Jim Bennett's Avatar
I just wave my magic wand, and POOF, I am outside.
Or, if the wand isn't handy, I would push open the escape hatch (window) which is in the rear opposite the door, where I imagine most would be.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 05-09-2013, 12:36 PM   #3
LindaK's Avatar
Trailer: 2009 17 ft Escape
I posted this on another thread (off-topic), so here it is again.
Here is a photo of the escape hatch in the ParkLiner we just sold. It is in the kitchen area centered over the aisle, directly in front of and above the stove, in the 6'5" tall ceiling. Not sure how one would actually escape using this hatch. I guess I would also need a magic wand.
Linda
LindaK is offline   Reply With Quote
Old 05-09-2013, 01:40 PM   #4
Trailer: Trillium 13 ft (green grape)
For the roof e/hatch you just tip the trailer on its side and crawl out. right???
RRJR is offline   Reply With Quote
Old 05-09-2013, 02:00 PM   #5
Ed Harris's Avatar
On my Trill 4500 1/2 of the rear window unit was a swing-up panel that I think was intended for us to slither through?
My 1300 had none at all?
On my Scamp 16' it was above the bed and on 2 Casitas the rear curbside window pops open as well as having a slider in it with a screen. This is where scoundrels broke in to my '01 SD too.
The Fiberstream,you are on your own I guess but each of the main windows seems big enough to use depending on how big you might be?
Ed
Ed Harris is offline   Reply With Quote
Old 05-09-2013, 03:22 PM   #6
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
My hatch this year is stink bugs. They're not clever at escaping.
jack
Old 05-09-2013, 03:27 PM   #7
Byron Kinnaman's Avatar
That looks like the escape hatch/vent in my Scamp. However it's over the end of the table. I would have to climb on the table to escape through it.
Old 05-09-2013, 03:29 PM   #8
jack
So- no secondary egress on Burros?
Francesca
P.S.
Maryland?
Heh heh heh...you're probably more preoccupied with another "hatch" just now! Isn't this a Year of The Cicada?
Old 05-09-2013, 04:24 PM   #9
rabbit's Avatar
Delaware
Some from western MD some DE. All eggs hatching now. No worse than rabbits in Oz but a plague nonetheless. Making light trap from litre bottle. Back to regular programming.
jack
Old 05-09-2013, 04:54 PM   #10
LindaK's Avatar
Hadn't thought of that!
Linda
Old 05-10-2013, 05:15 AM   #11
Steve L.'s Avatar
On my Casita 16 it's on the driver side wall. Presumeably on any wall (or ceiling) except the side with the door. If the trailer was on it's side blocking the door you still have an exit. (I don't know, maybe a wind storm knocks it over with you in it)
Steve L. is offline   Reply With Quote
Old 05-10-2013, 07:12 AM   #12
Bob Miller's Avatar
Trailer: Class A Motorhome
As I understand, there "used" to be a requirement for an escape hatch if the kitchen area (meaning stove) was located between the primary sleeping area and the exit door. For this reason it seems that a lot of Class "C" motorhomes up until the mid-80's had an escape hatch over the cab over bed area should a kitchen fire block access to the door.
In Toyota Mini-motorhomes this was common practice up until about 1988 when they seemed to have disappeared.
In our Lil'Bigfoot you can easily kick out the rear window as it's plastic. In the older Hunter Compact-II there is no such provision.
Old 05-10-2013, 02:29 PM   #13
On my Bigfoot 5th wheel, its over the bed over the hitch. Easy egress to the roof, and I guess, down the back ladder.
Cam A is offline   Reply With Quote
Old 05-10-2013, 02:53 PM   #14
Carol H's Avatar
My scamp has the same escape hatch that you could climb up onto the table to get out but I suspect in an emergency it would be faster and simpler to slide open the back window and head out that way - lot shorter fall! LOL
Old 05-10-2013, 04:18 PM   #15
rabbit's Avatar
Delaware
Mi burro also relies on either front or rear slider for emergency exit. Sliders at sides might work for tossing out dogs cats ferrets gerbils.
jack
Old 05-10-2013, 05:57 PM   #16
Brian B-P's Avatar
Not rabbits?
Old 05-10-2013, 06:12 PM   #17
We can chuckle about trailers laying on their sides, but the door becoming blocked by falling trees/branches is probably a lot more realistic. There are true emergencies (fire!) and less stressful emergencies... the door lock is broken and I can't get out. Having ANY egress is better than none and I'm glad the roof vent is big enough and made for getting out. The less damage I do to my trailer when I NEED to get out, the better.
Old 05-10-2013, 06:20 PM   #18
rabbit's Avatar
Delaware
Generic bunnies would fit; el Conejo is getting a bit broad of beam, Brian.
jack
escape
camping locations Ian-Vicki General Chat 20 04-29-2012 11:40 PM
Question about the escape hatch.. Marje Problem Solving | Owners Helping Owners 15 08-21-2011 12:10 AM
escape hatch interior trim sugermc Problem Solving | Owners Helping Owners 0 06-08-2011 06:50 PM
replacing escape hatch vent crank.. Christi V. Problem Solving | Owners Helping Owners 4 03-04-2009 07:16 PM
new seal for escape hatch on Scamp Gary Little Problem Solving | Owners Helping Owners 1 03-02-2006 01:24 PM
