Trillium 4500 Rims - Fiberglass RV
Old 08-23-2020, 06:16 AM   #1
Trailer: Trillium 4500
Trillium 4500 Rims
I found a used set of Rims 14" 5 on 4.5, but not exactly sure if they will work? Also what size Lug Nut would I need??
Just looking for some help before diving the 3hr round trip.
Cheers
Ryan
Redrider is offline   Reply With Quote
Old 08-23-2020, 06:47 AM   #2
The only problem I found was that the studs on my hubs were too short. So I had to replace them. I bought lug nuts to match those studs.
I really didn't find this out until I mounted the wheels to my Trillium.
I installed wheels from a Ford Ranger, which is a popular swap for the Trillium. Of course they were not trailer wheels.
Old 08-23-2020, 07:06 AM   #3
Are these rims made for trailers?. Most trailer rims are made with a zero offset, so if these are different will it be a problem on your trailer.
Old 08-23-2020, 07:33 AM   #4
Not sure what they came off of ? Definitely not trailer rims.
Old 08-23-2020, 07:36 AM   #5
[QUOTE=thrifty bill;790540]The only problem I found was that the studs on my hubs were too short. So I had to replace them. I bought lug nuts to match those studs.
/QUOTE]
The possible offset difference was what I was thinking could be an issue as well! Had not thought of the Studs being too short..
Old 08-23-2020, 10:21 AM   #6
Trailer: Trillium
I replaced the wheels and tires on my T4500 because they were very old and rusted and leaking, but used the original bolts that go into the brake drums. I used TR 175/80 X 13" Carlisle tires on white painted wheels I believe from Princess Auto. They fit perfectly and leave 3" travel room in the wheel well. I suggest that you try to stay with the original off-set and wheel/tire dimension or you may have problems.
jokra is offline   Reply With Quote
Old 08-23-2020, 10:26 AM   #7
Trailer: Trillium 4500, Casita f/d ,1987 boler voyageur,1988bigfoot5er
Hello Ryan,
Are they a set of four?
If they work I will buy the other two!
Bobby
Prickly
TV- 2013 Land Rover R2
1977 Trillium 4500---2008 Casita F/D
2008 Casita f/d-----1988 Bigfoot 5er---1987 Boler
Bobby Kirk is offline   Reply With Quote
Old 08-24-2020, 06:05 AM   #8
I passed on the Rims, just thinking they won't fit my application and probably best to keep it as close to stock OEM as possible.
Cheers, thanks for the info and advice
trillium
Rims on a Trillium Randy Bishop Modifications, Alterations and Updates 32 04-11-2016 10:46 AM
Hubcaps that fit my Trillium 1300 14" tire rims Jane in California Problem Solving | Owners Helping Owners 2 02-18-2015 01:32 PM
13 or 14 inch rims for my 76 trillium? Audrey Modifications, Alterations and Updates 8 02-08-2015 10:35 PM
Rims for a Trillium 4500 David Tilston Towing, Hitching, Axles and Running Gear 9 05-18-2012 10:03 PM
14" Rims on a Trillium Tim Ryce Towing, Hitching, Axles and Running Gear 10 04-14-2011 07:27 PM
