Parkliner: 2016 Air Conditioner - Fiberglass RV
Old 03-11-2021, 05:40 AM   #1
Trailer: Parkliner
Smile Parkliner: 2016 Air Conditioner
Has anyone replaced the room air conditioner put into the older models? I have been searching for something with easier access to the filter, maybe smaller and using less power. Priority is easy access to air filter for regular cleaning. Thank you.
Leslie14 is offline   Reply With Quote
Old 03-11-2021, 01:09 PM   #2
isn't the screen just behind the front grill? should not be hard to get off.
Do you have pets, or some other reason the screen to get dirty often?
Old 03-11-2021, 01:22 PM   #3
Trailer: Parkliner
Reason
Tom Bass, told me it would be hard to access. I’ve got screws out but need to unplug and have to move trailer to get to outside hatch for that. According to manual filter pulls out to the right. Area blocked by bathroom door trim. Reasons are dogs and lung cancer. Also think after 5 years it’s probably filthy. Might just need to modify how it is mounted but interested in options. Thanks for responding.
Old 03-11-2021, 08:05 PM   #4
Trailer: Parkliner
Virginia
If your 2016 is like my 2013 Parkliner, the air conditioner has to be pulled out of its compartment to gain access to the filter. As you said, the filter slides out to the right. My ACU comes out by removing the wood retainer strip in front of the ACU. Its screws are accessed from the bottom (use a mirror to locate them and see what kind of screwdriver you need - phillips type as I recall) With the wood strip removed, the ACU slides straight out toward the refrigerator. My power cord was long enough that I did not need to unplug it to get enough room to slide the filter out. If needed the receptacle for the ACU is on the left side of the opening and easy to get to with the ACU pulled out.
I tried to find another ACU with a front flip down filter access, but was not successful. The compartment dimensions limit what will fit. I did switch out the OEM ACU for a new one with 1000btu more rating and a remote control. It was just was too hard to get down on the floor to read and work the AC controls. The new unit's filter was also a right slide out type. I modified an universal AC filter kit to attach a filter to the outside of the ACU grill with velcro strips. This way, I do not have to pull the ACU out of its compartment to clean the filter.
hp in va is offline   Reply With Quote
Old 03-22-2021, 02:52 PM   #5
Trailer: Parkliner
Thank you Harry
Got the air conditioner out and was able to remove and clean the extremely clogged filter. Will likely put the same unit back in place but will be looking for a replacement at some point that has access to the filter from the front. You were right that the cord was long enough I didn't need to access the unit from the outside. Thank you.
parkliner
Air conditioner input air draw zack sc Problem Solving | Owners Helping Owners 8 10-02-2020 06:31 PM
Reset Air Conditioner on Parkliner Huck General Chat 9 06-14-2015 04:12 PM
Parkliner - Open Neutral at Air Conditioner Huck Problem Solving | Owners Helping Owners 27 05-16-2014 06:25 AM
ParkLiner air conditioner The West Virginian General Chat 6 08-31-2013 10:57 PM
Mounting air conditioner Legacy Posts Problem Solving | Owners Helping Owners 9 04-16-2003 10:47 AM
