08-04-2017, 10:41 AM
Trailer: 1988 Scamp Fifth Wheel
Scamp 19' fifth wheel towing -- Scamp hitch vs. converted 5th wheel
New to the Scamp game and wanted to check in on opinions of the new style Scamp hitch vs. trying to convert a 5th wheel hitch to a gooseneck. Like everything on forums like this these questions have probably been answered long ago, so if anyone has thread links that might help.
The Scamp hitch has the advantage of being purpose driven for the Scamp trailer but can't really be used for much anything else. My preference is something with wider adaptability that could also be used for, say, an Escape trailer later on rather than having to swap out a hitch in a few years if we go in that direction.
What I was thinking was in the realm of a typical Reese-type 5th wheel hitch and one of these kingpin to gooseneck adaptors:
What are the pros and cons of that sort of device versus the Scamp hitch? This solution also has the advantage of being more readily available locally versus something I'd have to have Scamp ship to me in North Carolina.
08-05-2017, 09:44 AM
Trailer: 2005 16 ft Scamp Side Dinette and 2005 Fleetwood (Coleman) Taos pop-up / 2004 Dodge Dakota QuadCab and 2008 Subaru Outback
Every once in a while I think of getting a 5th wheel, either Scamp or Escape, and I was impressed with this Andersen hitch. I don't know if they would resize the 2 5/16th ball for the Scamp, but it looks like this could be used if you went from a Scamp to Escape or vice versa.
Dave (and Marilyn who is now watching from above)
Sharpsburg, GA
04 Dodge Dakota V-8, 17 Dodge Durango V-6, 19 Ford Ranger 2.3 Ecoboost
radar1-scamping.blogspot.com
08-05-2017, 09:55 AM
Trailer: 2017 Escape 5.0 TA
Connecticut
Other than just watching a You Tube video I know nothing about the Scamp hitch. That being said I'm very surprised that it attaches to the truck bed and not the frame. I'm using an Anderson Ultimate hitch to tow my 5.0 TA and really like it. It uses a ball mount witch has an adjustable height. Not having actual dimensions couldn't say for sure but looks to me like it could work with Scamp set up. It is a much more robust set up that attaches to the frame not bed of truck. If it was me I'd get in contact with the people at Anderson and see if they can help. I think it's a great hitch.
08-05-2017, 09:59 AM
Connecticut
Radar1 beat me to it, but that is the hitch that I was talking about.
08-05-2017, 10:12 AM
Using an adapter like that might lead to too much play at the hitch. You want keep a snug hookup.
09-15-2020, 08:34 AM
Thanks Jason, I've got a 2019 Ford Ranger and have been looking to see what kind of hitch I'd need for a Scamp 19. I'm surprised that a standard 2" ball is the hardest part. What was your tow vehicle? You think that setup will work with my Ranger Crew Cab? Thanks. Al
09-15-2020, 08:47 AM
We towed with a long bed (6') Nissan Frontier initially and then upgraded to a Chevy Silverado when the Nissan proved to be insufficient for towing in some areas of the west -- the transmission was also starting to have issues on it. What we ended up doing was getting the ball and top metal plate directly from Scamp, then connecting it to more standard Reese components (Reese 58147 crossmember) for the rest of the system.
09-15-2020, 09:28 AM
Thanks Jason, Looks like they removed the 2" ball adapter from their web site. I'll give them a call but they may not want to sell just that part. Do you think the plate is something that could be made locally? Seems like it's just a thick metal plate with a bolted 2" ball.
09-15-2020, 09:33 AM
Yeah a good machine shop should be able to make a comparable version fairly easily out of plate metal with mounting holes that match the crossmember you use. It was easier for me to just buy it all together because I bought a large number of items from Scamp anyway, but it might be easier on your side to have it done locally and just buy a common 2" ball.
09-15-2020, 12:48 PM
Odds are that your buyer would want the hitch with the Scamp when you sell. Then you would simply buy the correct hitch for your replacement trailer.
Better yet.... buy the trailer you really want in the first place.
09-15-2020, 01:21 PM
Trailer: 2015 Escape 5.0TA
A Scamp 19 hitch does necessarily have to be mounted to the truck bed rather than the frame. Scamp specifies the maximum distance from the ball to the two corners of the tow vehicle’s rear bumper. My memory of minutia is not that great but if I do remember correctly, the maximum is something like 56” or 59”. It would be best to call Scamp and ask. The specified distance is critical so that the trailer does not contact the bumper in turns. As a result, the connection point is often slightly behind the tow vehicles axle rather than in front of it. The tongue weight of the Scamp 19 is not so heavy as to exert a lever effect lifting the front wheels of the tow vehicle causing handling issues, which is why gooseneck and 5th wheel hitches are generally slightly in front of the axle. This maximum distance sometimes precludes the option of using standard frame mounted brackets. A good welder could likely fabricate brackets that could be attached to the frame. The Scamp 19 is a very stable tow. My only complaint, if you can call it that, in three years I wasn’t able to drop the coupler onto the ball and lock the coupler (not even once) without pulling the truck forward or reversing a couple of inches, and I could then lock the coupler. As part of the hook up routine, I would get in the cargo bed and have my spouse “jerk” the truck forward or backward. As soon as I heard the “clunk,” I could move the locking lever to the locked position.
09-15-2020, 01:32 PM
Nebraska
I have a 2003 Chevy S10 Crew Cab LS with the 4.3L 6 cylinder engine... It's rated at 5,200' for towing and 1,111' for payload. I had inherited it from my father when he passed in 2011. I wanted to get a camper that was large enough that it could be comfortably used with our two grandgirls (ages 5 & 6), but small enough to be pulled by the S10... The Scamp 19' seemed to fit the requirements...
I drove my S10 to Backus, MN and had Scamp Eveland's install the newer 5th wheel hitch (with the quick release) before I picked up the trailer; the previous owner had the old 5th wheel hitch (with no quick release).
09-15-2020, 01:53 PM
Trailer: 2002 16 ft Scamp
Hi Al, enjoyed talking with you this afternoon and wish you the best on getting things sorted out.
The hitch plate is 1/4" thick flatstock and 16 7/8"L x 6"W.
It attaches with six grade 8 bolts with nylock nuts. I'd guess these are 3/8" or maybe 7/16" in diameter.
Just let me know if you have further questions
09-16-2020, 06:08 AM
Trailer: in the market
Can the Anderson hitch be used with the Scamp 5th wheel?
10-31-2020, 01:44 AM
Nevada
Except for the top plate (in the pic it's the piece with the 6 bolts) that has the ball, all the rest are off-the-shelf 5th wheel parts.
Jason (post above) has the parts listed out. I wonder what the cost is if you bought the pieces like listed, individually?
11-09-2020, 05:50 PM
Nebraska
The first time I had hooked up the Scamp (driving from Minnesota to Nebraska), a sales manager from EBY Trailers in Story City, IA (where I spent the night) pointed out to me how my S10 was experiencing "squat" (which can affect handling). He recommended to me the Timbren SES (suspension enhancement system) to prevent squat. I purchased the SES kit from eTrailer.com and installed it myself.
https://timbren.com/p-35851-timbren-ses.html
11-12-2020, 09:13 AM
Trailer: Scamp 19 ex Casita 16
Georgia
Lil Rokr legs and fabricated ballplate
2001 Dodge Dakota
