01-23-2021, 08:39 PM
#41
Trailer: in the market
Whew! You all have given me much to think about. I see it's not just the weight you have to consider. I can see how the wide Scamp might not be the best match for the CX-9 (or maybe even the Highlander?)
I'll look at both owner's manuals and see.
I'm not set on what vehicle and am checking out which might best match my needs.
So....given the wide girth of a Scamp, do any of the mid-size SUV's fit the bill or do you have to go bigger.?
I will be using the vehicle mostly for daily driving, but we will be out camping some too. I soon will retire, so I'm playing it by ear and would like to get a vehicle that gives me flexibility no matter what I decide.
01-23-2021, 09:09 PM
#42
Scamp is not wide. It’s about the same width as typical 3-row crossovers. It’s a bit taller, that’s all. It will not be a problem. Many people tow 13’ Scamps with even smaller vehicles like a Subaru Outback or a Ford Escape.
01-23-2021, 09:25 PM
#43
In the SUV class, Highlanders are popular tow vehicles as are Pilots. I’d put the CX9 in that group. I’ve been considering a Telluride, no rush since we aren’t traveling. The 13 footers can be towed with some of the smaller SUVs.
Since I’m a truck guy, my F150 always stands ready for tow duty. But on trips where we set up camp in one spot for a while, an SUV would be handier.
01-23-2021, 09:45 PM
#44
Name: Borden and Carole
Camper speed limits
Originally Posted by Campingbliss
The 13” class C tires that come with the Scamp are only rated for 55mph. I would not drive above 60mph.
They make ST radial tires. have them on our trailers. Was told some states set a 55mph limit on all camping trailers regardless and in some provinces was told it is a limit of 90kph while towing a camper. They do not enforce it in Canada unless you have an accident.
Our postage stamp in heaven.
01-23-2021, 09:50 PM
#45
TV
Scamp is not wide. Its about the same width as typical mud-sized crossovers. It’s a bit taller, that’s all. It will not be a problem. Many people tow 13’ Scamps with even smaller vehicles like a Subaru Outback or a Ford Escape.
Subaru Outback; check its towing capacity, it is actually 2700 lbs
01-23-2021, 09:54 PM
#46
Transaxle cooler
Originally Posted by bertherr
Mr Transmission sells a sweet little transaxle cooler
01-23-2021, 11:20 PM
#47
NW Wisconsin
Many are towing an Escape 21 with the Highlander without issue
01-24-2021, 12:35 AM
#48
I towed my Escape 17B with my RAV4 Sport V6 for twelve years. Just bought a Highlander XLE, which is more than sufficient as a tow.
Be wary of too assertive posts, like "only tow at half the rating".
01-24-2021, 07:22 AM
#49
It's gotten a little confusing since this thread took a detour back in post #22 to discuss the CX-9, which is Mazda’s mid-size, 3-row crossover, rated for 3500#. The CX-5 that started the thread is a compact, 2-row crossover rated to tow 2000#.
I was referencing the CX-9 when I described the Outback as a smaller vehicle. I am aware of the Outback’s rating, and it’s a fine tow vehicle for most 13’ Scamps, limited somewhat by a low tongue weight rating on older versions. The latest 2020 redesign made it even better, as it allows for higher tongue loads common on fully optioned 13' front bath models with dual LP tanks.
The CX-5 is adequate for lightly-optioned Scamp 13's, while the CX-9 is more than adequate for any 13'er and some 16'ers as well. The CX-5 has pretty consistently ranked near the top of its class for reliability. The CX-9’s record is somewhat mixed. That’s the only caution I’d offer.
01-24-2021, 02:05 PM
#50
2019 Mazda CX-5 with 2000 lbs add transaxle cooler and looks like a go; refer to original post. 13' boler so most likely under 1000 lbs we use a wd system to tow with fixes the tongue weight but at 100 lbs or less recommended for cars 8 to 9 percent do not think there is a problem. WD really is more for larger trailers but they must have one that light. At 1000 would need a tongue weight of only 80 to 90 with a car. The trailer would likely be under 1000 lbs.
01-24-2021, 02:45 PM
#51
...13' boler so most likely under 1000 lbs ...The trailer would likely be under 1000 lbs.
Reality check from the "Trailer Weights in the Real World" database.
Weights are axle, tongue, total (pounds).
13' Boler Weights
13' Scamp Weights
Admittedly small sample sizes, but none under 1000#. Not even close. Most exceed 200# on the tongue.
01-24-2021, 03:36 PM
#52
Sorry to have sort of hijacked the OP's thread. I was piggy backing on his concern about towing the Scamp 13 with a CX-5. The CX-9 was on my list of possibilities for towing so I chimed in. After researching and reflection, I'm veering toward the Highlander now anyway. Lots to consider and learn on this adventure. Thanks for the input.
I haven't bought said trailer yet, so a bigger tow rating would be nice and offer some flexibility.
01-24-2021, 09:15 PM
#53
Good thinking here. The Highlander gives you options and flexibility, and its a fine vehicle.
01-25-2021, 10:28 AM
#54
That’s certainly a solid choice. Good reliability and, at 5000# towing, a number of larger trailers are back on the table, now or in the future if your needs change.
The 5000# class is tow-tested with a minimum 40 sf box trailer.
Three-row crossovers are a crowded field, and you would do well to check out some of the competition. I have found Honda seats more supportive for all-day driving. Of course that’s a very personal call, but don’t underestimate its importance. Nothing worse than squirming all day trying to get comfortable and arriving with an aching back.
01-26-2021, 12:34 AM
#55
Jon,
I thought the Pilot would be great but the new ones have an issue with the infotainment system-class action law suit etc. It kind of scared me away. The Highlander does too-that being with the transmission. Ugh. I am probably over-thinking this. It seems almost any brand will have problems in some area.
The Mazda was rated # 1 in reliability this year, but I'm not sure it's the best choice for towing. Highlander Hybrid is on my list and yes, still the Highlander gas and Pilot.
01-26-2021, 08:18 AM
#56
Welcome to the exciting world of vehicle-shopping! Thanks to the internet, we have more information about vehicles than ever before, but it can be hard to sort the facts from the noise.
Seems like you are putting together a solid short list. Whether to keep the CX-9 on it is your call. The lower tow rating means few trailer choices, but it will be fine with a 13-16’ trailer. With a 5000# rating, you can move into the 17-19’ class. The final purchase may well be influenced by driving impressions, cost and availability, and the “just-feels-right” factor.
I had heard about the Honda infotainment woes. I've always thought Honda could use some help with user interface. We've had three, and all had some oddly placed controls. Sad because they're otherwise solid vehicles.
