Spare TIre Mounting 19' Scamp - Fiberglass RV
Old 11-09-2020, 08:33 AM   #1
Hollywood
I have a 1987 19' Scam that has 15" tires.
the clearances are OK and I like the bigger tires.
The spare is held on by only one bolt with minimal threads showing.
The alignment the lower two will not line up due to the larger tires. The photo shows the tire resting on the rear Bumper.
The mounting plate is available from scamp that will not fix this by itself.
I have a 2" receiver on trailer for carrying bicycles with a 12" extension to clear the spare tire.
Any ideas for a fix?
Thank you
TOM
Tcjmiami is offline   Reply With Quote
Old 11-09-2020, 10:59 AM   #2
Virginia
Maybe you could use your current bolts to secure a plate that has bolts properly spaced & elevated so that the tire clears the bumper when mounted. I am thinking about just a flat plate but I will attach a link to somthing that canbe purchased just to get the thought across.
When I went to larger wheels & tires on my 2000 19' the spare just barely fit on the back. It actually rested on the bumper.
Bert
https://www.amazon.com/Extreme-Max-3...%2C237&sr=8-23
bertherr is offline   Reply With Quote
Old 11-09-2020, 11:35 AM   #3
Hollywood
Bert
Thank you for the reply.
I was just hoping to get lucky and find a ready fit.
I will get a plate and build it to fit.
Tom
Old 11-09-2020, 11:53 AM   #4
Timber Wolf's Avatar
North Florida
When I replaced my 4-lug axle with a 5-lug I made a plate catching the two original bolts to hold it and added two more. The top bolt goes all the way through to hold the rim. I probably made it heavier than required, that’s just how I roll.
Old 11-09-2020, 12:27 PM   #5
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Bumper mounted spare tire carrier. That way there are 3 fewer holes in your Scamp.
Old 11-09-2020, 04:54 PM   #6
AC0GV's Avatar
Wisconsin
Adaptor plate
Any ideas for a fix?Thank you
TOM
If your sure it fits your Scamp, I too would make an adaptor plate. Holes to fit the Scamp bolts and studs to fit the six-hole wheel.
AC0GV is offline   Reply With Quote
Old 11-09-2020, 05:09 PM   #7
Hollywood
Thank you all for the replies.
I am going to make an adapter plate.
Mounting a spare tire raddar Modifications, Alterations and Updates 5 05-06-2017 07:54 PM
Spare Tire Mounting for Lil Snoozy JBB Problem Solving | Owners Helping Owners 10 12-04-2016 06:01 AM
Spare Tire Mounting jack smith Problem Solving | Owners Helping Owners 12 03-17-2013 07:19 PM
Wanted:"Old style" Scamp spare tire cover Tony Nowak Classified Archives 1 08-01-2007 01:12 PM
Trillium 4500 spare tire mounting Joe Loiacono Problem Solving | Owners Helping Owners 4 07-20-2007 09:36 PM
