Surfside converter grounding - Fiberglass RV
Old 05-22-2022, 02:46 PM   #1
Trailer: Currently Shopping
Newfoundland
I have a ‘79 surfside with the original power converter (see photos). I’ve boondocked a few times and took along my 600 watt portable power unit plugged the shoreline power cord from the converter into one of the AC outlets of the power box. I’ve been able to power up the trailer including interior lights, fans and AC receptacles, basically using the power box as a substitute for shore power.
Now for my questions:
1. There doesn’t seem to be a dedicated wire running from the grounding screw of the converter directly to the metal trailer frame. Should there be one? The shore power supply cord has its ground wire connected to this screw.
2. The panel of the converter says 12V AC. I always thought the 12V power coming out of the converter was DC. Is this not the case?
Here’s a link to my power box.
https://www.canadiantire.ca/en/pdp/m...2014p.html#plp
78DF1DBB-C89A-4E0D-97A9-0572D2C39775.jpg   C114F0E4-2D76-4854-B510-A47603A0E9A6.jpg
JasonGill is offline   Reply With Quote
Old 05-24-2022, 08:09 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
newer converters would be DC, some of the old ones used AC, these would not charge a battery, but would run 12v lighting.
there doesn't appear to be a DC section in that unit, and someone has definitely been playing with the wiring looking at the crimp taps that were added.
I would consider an entire new unit if you are going to do a lot of camping with services.
Joe
Old 05-24-2022, 08:46 AM   #3
Trailer: Bigfoot 25 RQ
Ohio
Looks dangerous. A new converter would be a wise choice. Progressive dynamics would be a great choice. If you call bestconverters.com they can advise you.
oldwave is offline   Reply With Quote
Old 05-25-2022, 01:40 PM   #4
What you have there is a transformer to make the 12VAC. Even though it looks rusty, that thing should last forever and I dont think it is dangerous. As far as 12VAC, I see no use for it and go along with others and recommend a new unit that will give you the DC power you need and to charge your battery if you have one. If you do not have a battery or need 12VDC then I would just leave things alone.
Old 05-25-2022, 04:11 PM   #5
Ohio
What’s dangerous in my opinion is inadequate grounding. I have personally been shocked back in the old days with wet ground and a similar system .
Old 05-25-2022, 04:20 PM   #6
You are absolutely correct about that.
surfside
Surfside converter grounding JasonGill Electrical | Charging, Systems, Solar and Generators 0 05-22-2022 09:47 AM
Grounding a Scamp Thee Jimbo Problem Solving | Owners Helping Owners 9 08-28-2015 07:39 PM
Grounding 120v to the frame... KyMoonshine Electrical | Charging, Systems, Solar and Generators 11 01-15-2015 02:28 AM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Grounding Tail Lights with no White Wire Tim Bas Problem Solving | Owners Helping Owners 2 08-11-2010 03:27 AM
