Rain gutter ideas on Scamp 19 - Fiberglass RV
Old 08-18-2020, 10:01 AM   #1
NH-Boomers's Avatar
Name: Jane and John
Trailer: 2017 Oliver Legacy Elite 2
New Hampshire
So we are curious what folks are doing to prevent rain coming down under the awning on the Scamp 19? In the past ( on the Scamp 13 and Scamp 16) we installed a piece of rain gutter and caulked it so the water ran down to the ends but the Scamp 19 poses more of a challenge with the angle up to the loft area. Any suggestions would be great! 😊
Thanks in advance
NHBoomers
NHBoomers Charlestown NH
Currently own 2017 Oliver LE2-T
NH-Boomers is offline   Reply With Quote
Old 08-18-2020, 10:19 AM   #2
floyd's Avatar
I found the perfect solution for the Catalina 2500.
I simply dropped a length of PVC pipe into the gap from above and sealed it from above with silicone caulk. It is invisible and forms an excellent gutter which seals the awning.
Some iteration of this method would work well with your awning which has a larger gap. Perhaps a larger pipe or even a modified PVC gutter would do well and offer a good and permanent solution.
Old 08-21-2020, 07:23 AM   #3
NH-Boomers's Avatar
Name: Jane and John
New Hampshire
Rain gutter behind awning
So on our Scamp 19 we have a long straight space then it angles up tor the loft area so we are gonna put a gutter and a j channel piece coming down to meet the gutter and caulk it all all. It’s quite a large space that tapers down. Fingers crossed, we will post pics when it’s done
Old 08-21-2020, 08:28 AM   #4
floyd's Avatar
They do make this stuff...
It has limited effectiveness , but it looks good and is easy to install without harming the surface.
https://www.amazon.com/Trim-Lok-Drip...N8TAMW1TRZC8D6
Old 08-21-2020, 10:19 AM   #5
NW Wisconsin
We recently installed the EZE gutters that Floyd pictured in post #4
They do work / help but as Floyd pointed out they are only marginally effective and they are not inexpensive
One pointer if you want them to stick & stay , preparation/ cleaning the surface is key .
Gutter extentions tacker Modifications, Alterations and Updates 2 05-30-2017 11:52 AM
Using Gutter Clips for Patio/Awning Lights Donna D. Modifications, Alterations and Updates 10 04-09-2015 09:28 PM
LF Trillium Rain Gutter Kevin Woods Care and Feeding of Molded Fiberglass Trailers 13 08-15-2007 07:00 AM
Door Gutter Legacy Posts Problem Solving | Owners Helping Owners 6 06-09-2003 02:32 PM
