I have a 2010 made by Trilliumrv. It's my understanding they were bought out by Great West who made the side kick. My trailer has a vinyl wall covering with a yellow foam backing. Same stuff?
It doesn't make sense to me that there would be condensation behind the covering. I had a belly band leak due to poor manufacturing. I was able the remove the covering with heat and gentle persuasion. After repairing the bellyband, I reglued the covering using contact cement. I bought a small jar at Walmart.
Because of the curves in the body, replacing the wall covering on any of these trailers is considered a major undertaking. It seems to me if the wall covering is coming lose, a leak is the most likely cause. Worse than replacing the wall cover, is the replacement of the plywood floor. I'd be looking for soft spots in the floor due to rot. Good luck.
