UHaul 16FT VT Gas Prop Lift Supports 10"? - Fiberglass RV
Old 03-13-2013, 09:07 AM   #1
Darnold12's Avatar
Trailer: Sold:::SCAMP
Question to my UHaul experts. Looking to purchase 2 front window LIFT Supports but since our VT didn't come with any, not sure what was originally there? 10" ??
And if the new ones offered fit our OLD brackets or will those have to be replaced also?
Thank you
Deb/Ron
Deb/Ron's Project
Darnold12 is offline   Reply With Quote
Old 03-13-2013, 09:47 AM   #2
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Sorry can't help mine did not have one. I sorta like it that way as I can see through while towing. Just my preference
Michael J.
mmeyer is offline   Reply With Quote
Old 03-13-2013, 12:42 PM   #3
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Same here. No covering and hubby wants none unless it is made of something clear.
CindyL
Old 03-13-2013, 01:12 PM   #4
George Lauver's Avatar
Trailer: 85 Uhaul CT 13
Deb,
I purchased the 15 lb. gas springs with the ball joint fittings from McMaster-Carr. Mine are 12.2" overall; however I sorta wished I had gone with the 9.65" to leave a little more down slope to the shield.
George Lauver is offline   Reply With Quote
Old 03-13-2013, 02:56 PM   #5
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
Georgia
I bought new struts at the auto parts store. I think I went with StrongArm 4420. They fit perfectly. I just took the old one in with me and matched it up.
--Sean
1984 Uhaul CT 13
TV: 2015 GMC Acadia V6, 2008 Jeep Wrangler Rubicon, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 03-13-2013, 03:20 PM   #6
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
If we can confirm I will add to the cross reference. I wonder if these were added later as there is no reference to rock guards or gas struts in the manual. Also noticed a reference to a screened window in the front and the rear in the parts manual and sorta in the repair manual. More areas to amp up the speculation meter.
Old 03-13-2013, 06:10 PM   #7
Sean, how many pounds pressure are your struts? The lowest I found at an auto parts store were 30lbs; much too heavy for the rock shield! I think the origional were 10 lbs.
Old 03-14-2013, 08:26 AM   #8
I looked up the StrongArm 4420 strut and it is rated at 30 lbs, with a list price of $30 each; although I found it online for $25 and change. The McMaster-Carr is priced at $15.15 ea. and I received my order in 3 days.
Old 03-14-2013, 08:47 AM   #9
knighth001's Avatar
Georgia
I believe they are 30# but they work fine. They don't pop out too fast or anything. I think I paid between $30-40 for both of them together. They definitely weren't $30 each at autozone.
--Sean
1984 Uhaul CT 13
Old 03-14-2013, 09:10 AM   #10
Trailer: U Hall VT
I did away with the gas shocks as I couldn't find the 10# and made sliders with thumb jam nuts, work great, I had the shocks on at first, then in Texas the lock came apart and up went the rock shield, going down the road, stopped and strapped it down, took off the gas shocks, went on.
Roger Kimble is offline   Reply With Quote
Old 03-14-2013, 09:36 AM   #11
McMaster-Carr does sell a 10# gas spring that's stainless steel; however it's priced above $60. Too rich for my blood; that's why I opted for the steel 15 pounder.
Old 03-14-2013, 10:25 AM   #12
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
These were perfect replacements
I tried 10# struts but they were way too weak. I replaced them with these off eBay. These have worked perfectly for fit (after replacing the end fittings), appearance and function. (25# force, 12" long) He ships immediately and shipping was only $7.90
Columbia Stut CS1200-25
2ea HD RV Bus Marine Boat Storage Box Gas Strut Cylinder Spring Lift 25 12" | eBay
The end fittings also on his website:
http://www.ebay.com/itm/4ea-10mm-Bal...item4abd4d84e4
djtriceflt is offline   Reply With Quote
Old 05-09-2013, 11:41 PM   #13
Perk's Avatar
Trailer: Formerly U-Haul
I replaced my front window rock shield struts. I went to a camper shell shop and bought these and they seem to work just fine. They are 28lb rated. They hold the shield open very well and close easily. When the shield is completely closed the struts seems to relax or reduce their pressure. I hope this may help someone.
Perk is offline   Reply With Quote
Old 05-10-2013, 07:34 AM   #14
Brian B-P's Avatar
That sounds like over-centre geometry: the struts are most compressed (and thus exerting the most force) just before the guard is closed all the way, and then extend again a bit (so less force) when the moving ends come closer the to body than the fixed ends, due to the length of the mounting brackets. This is good, because the strut helps hold the guard closed this way, rather than always pushing it open.
It could also be that it's just the change in leverage: with this mounting arrangement the strut is much more directly pushing the guard open when it is up than when it is down. That's a good thing, too.
Either way, it's not likely any feature or characteristic of the strut itself, but it's a good observation.
uhaul
Axle winterizing... To lift or not to lift??? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 22 12-12-2015 06:47 PM
For Sale 1988 UHaul 13" $4,500 Alan P. Referrals: Molded Fiberglass Trailers 0 09-21-2010 05:21 AM
Just gas or gas/electric water heater? Feedback wanted. Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 09-15-2010 09:11 AM
