How to fix my scamp table - Fiberglass RV
Old 09-26-2021, 12:07 PM   #1
Trailer: Scamp 1995 19'
At the back end of my 1995 Scamp 19' is the table and bench seats. The left side of the table has forever been "slipping out" and dropping. I finally looked at the underside and the left most bracket that the wire rests in are missing all four screws. I found two but...
I assume there must be a piece of plywood behind that area that the screws screw into? I tried screwing back in and nothing! I am afraid to just go with longer screws since, not knowing what is back there, I could go right through the fiberglass.
Does anyone know if there is in fact a piece of plywood in the wall behind the table mounting brackets? It looks like I could just offset the bracket towards the middle an inch and have fresh wood to screw into, assuming there is any of course.
JWColby EAAT
Exalted Arbiter of Anal Tripe
jwcolby123 is offline   Reply With Quote
Old 09-26-2021, 02:17 PM   #2
https://www.fiberglassrv.com/forums/...ets-58825.html
Old 09-26-2021, 06:11 PM   #3
Originally Posted by gordon2 View Post
Precisely what I needed to know.
JWColby EAAT
Old 09-26-2021, 07:30 PM   #4
Good.. now its your turn... and going totally off topic (might move this to the other thread but it went off topic and is now about inverters )
  • My Chins 100Ah LifePo4 arrives in four days.
  • I want to use it in the 20 - 80 % charge range.. For the most part I am not worried about 80 Ah vs 90-95 Ah available but the option to charge it all the way would be nice.
  • I have a PD9100 converter with Charge Wizard. I can remove the Charge Wizard.
  • I also have a CTEK 7002 charger.
  • I'm having a heck of a hard time figuring out if either or both of these chargers will be OK, or if I should buy a LifePo4 charger. So what do you think? Buy a new charger?
Ctek 7002:
Normal mode: 14.4 VDC
Snowflake mode: 14.7 VDC (.1 over max for Chins LifePo4)
Supply: 13.6 VDC
Recondition Mode: Not even worth mentioning.. 15.7 VDC and way over max limit.
PD9100:
13.6 VDC, 30 amps
PD9100 with charge wizard:
Norm mode: 13.6 VDC
Boost mode: 14.4 VDC (prob has to be manually activated)
Storage Mode: 13.2 VDC (if no load in 30 hours)
Desulf Mode: 14.4 VDC for 15 minutes every 21 hours.
My concern with using the Boost mode with the charge wizard is that it might end too soon to charge the LifePo4 since it "thinks" it is charging a LA or SLA. Then would the Desulf mode for 15 mins every 21 hours be enough to do the additional charging for the LifePo4 over a lead acid?
I guess what I want is a BMS that reports the true state of charge... maybe this $360 100Ah LifePo4 is not the best choice, but that price!
Chins Specs
Charging Limit Voltage: 14.6V
Over Voltage Disconnect Voltage: 15V
Over Voltage Reconnect Voltage: 14.2V
Float Charging Voltage: 13.8V
Discharging
Low Voltage Disconnect Voltage: 10.8V
Low Voltage Reconnect Voltage: 11.6V
Under Voltage Warning Voltage: 12.4V
Old 09-26-2021, 08:13 PM   #5
Here's what I think
Ctek 7002:
Supply: 13.6 VDC
PD9100:
13.6 VDC, 30 amps
Norm mode: 13.6 VDC
Chins Specs
Discharging
I believe that the charger doesn't work on time but rather on amps being accepted by the battery. If you think about it, the charger doesn't know how big the battery is, and therefore can't "know" how long it is going to take to charge, it can only know how much current is being accepted at any given time.
So I believe that the charger watches the current profile. Which of course is entirely different in a LiFePO4 than a PbA battery. The charger will see a huge current being accepted clear up to the knee of the LiFePO4 and will continue to provide that current. In effect it will "think" that you have a huge PbA battery.
Now... when that current starts to drop, which is determined by the battery not the charger... then it will switch modes, thinking that the PbA battery (which it believes it is charging) is now about 80% charged and thinks it therefore needs to slow down the charge current.
But... by then your LiFePO4 battery is already starting up the knee and almost fully charged, probably about 95-98% charged.
The only "gotcha" here is that you will have to tell the charger to start charging, by pressing the button on the dongle thingie.
BTW even this is not entirely true. The LiFePO4 will eventually drop into the discharge knee and the charger will eventually see a voltage that it believes "needs charging" (around 12.2 maybe?) and will turn on the charge current. The only downside is that the battery will discharge clear down to that discharge knee before the charger turns on.
Other than that, I believe that the charger works as well or better than with a PbA because the battery itself accepts high current all the way to almost charged.
That is what I believe.
JWColby EAAT
Old 09-27-2021, 06:18 AM   #6
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
John, if the wood isn’t rotted and the screws holes are just enlarged, you may also want to consider threaded inserts. Drill the existing holes larger being careful not to drill too deep. Install them with a screwdriver (some are made to be used with an installation tool, basically a driver that fits in a recess). Then you can use bolts or machine screws (with blue Locktite) to attach the brackets.
Old 09-27-2021, 08:29 AM   #7
Unless I cut open the rat fur there isn't a way to assess the condition of the holes.
I'll probably just shift the bracket right an inch and start with new screws.
JWColby EAAT
Old 09-27-2021, 03:53 PM   #8
I believe I will need to do some testing...
The Charge Wizard insert says
In boost mode they charge wizard automatically increases converter output voltage to 14.4 volts DC when it senses your battery is heavily discharged. This mode will recharge your battery to 90% of full charge in two to three hours which is about 300% faster than other products. After your battery reaches 90% of full charge, the charge wizard automatically returns the power converter to the normal mode to safely complete the charging.
Now the boost mode can be initiated by pressing the button but with the inherently higher voltage in the LifePo4, the Charge Wizard might well think the battery is 90% charged too soon and lower the voltage. And it might even have a time out. So I'' try it and see what happens.
Old 09-27-2021, 07:43 PM   #9
Yes please
What does "90% charged" mean? Inconvenient that they do not specify. However I think they are watching the current, not the voltage. If that were not the case then the Battle Born batteries could not use a lead acid profile, and Battle Born claims that their battery can just be dropped in.
I have pressed the button many times. It starts a flash pattern indicating that it is doing a charge. I have never actually run down the battery to the point where a charge should start automatically.
I keep my rv plugged in while in my driveway. I do take my daughter "camping" locally where we are off grid however the battery is so large that we never actually run it down to the discharge knee, since I only have a 300w inverter ATM, and we only use that for plugging in our computers.
When we come back I plug back in. I do not expect the charger to understand that the battery needs charging unless it is down in the discharge knee. So periodically (or before a camping trip) I reach over and press the button.
It is my understanding that pressing the button forces the charger to start a charge cycle. I don't believe it will "automatically" charge unless the battery is down in the discharge knee at a voltage similar to a lead acid battery would be.
JWColby EAAT
Old 09-28-2021, 08:02 AM   #10
What does "90% charged" mean? Inconvenient that they do not specify. ...
Thats the $64,000 question. PD is very vague about their product.
Old 09-28-2021, 01:33 PM   #11
1.25" #6 screws aren't long enough
I bought #6 1 1/4" screws to fasten the bracket to the wall. It seems that the insulation and rat fur is that thick. The screws never even touched wood.
I shifted the bracket to the right (centerwards) one inch and then I screwed them in as far as I could press the bracket into the rat fur. It is "holding" but not in wood. It sure looks like a 2" screw is in order.
Or the wood is rotted. But it just didn't feel like there was anything solid back there.
JWColby EAAT
Old 09-28-2021, 02:33 PM   #12
Could be.. sometimes the spare tire bracket leaks. Did you use the same size screws that are on the other side? If so maybe time to strip off some rat fur and check the wood, including moisture content. Rat fur can me reapplied and look almost as good a original.
Adding a front table to a Scamp using the Lagun Swiveling Cockpit Table Mounting Syst gordon2 Modifications, Alterations and Updates 26 08-30-2020 11:12 AM
Suger's Scamp Fix-Up sugermc Modifications, Alterations and Updates 28 10-04-2015 06:01 PM
How to fix crack in table davis Problem Solving | Owners Helping Owners 0 04-16-2013 09:27 PM
How to fix a scamp door Mary Ann in MN Problem Solving | Owners Helping Owners 9 05-07-2011 06:06 AM
Scamp door fix questions (recurve) LanM Problem Solving | Owners Helping Owners 0 08-01-2010 11:58 AM
