Scamp 13 Water Tank Location - Fiberglass RV
Old 10-30-2021, 05:35 PM   #1
Maine
I have a 1986 scamp, the water tank had been removed but was still with the trailer. I am going to put it back in and am wondering where under the dinette bench Scamp would place the tank. Did they tuck it close to the freshwater fill spout? Or is it better for weight reasons to move it closer to the wheel well?
peedee360 is offline   Reply With Quote
Old 10-31-2021, 06:58 AM   #2
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
My 2007 13' deluxe tank is mounted under the door side dinette seat with the drain valve attached directly to the tank and positioned over a hole in the floor. This leaves enough space for my electric water pump to be mounted in front (toward the front of the scamp) of the tank. You may not want/need a electric water pump and I'm simply mentioning it as a reference point on tank positioning.
Hope this helps a bit!
2007 Scamp 13' deluxe
RSchleder is offline   Reply With Quote
Old 11-04-2021, 02:36 PM   #3
AC0GV's Avatar
Wisconsin
Where ever it fits
You will be forced into picking the location. Start by lining up the drain hole with the drain valve hose. You will find it VERY hard to get your hand tools in position to tighten both the hose clamps (fill and vent) and the straps. Then place the 12 volt pump (if you are using one) in the space remaining. This will be a good time to install a winterizing hose as well. I have also installed an accumulator tank to prevent the pump from short cycling when running water slowly. Picture is a 16'.
AC0GV is offline   Reply With Quote
Propane Tank Location TheSpencerJM Care and Feeding of Molded Fiberglass Trailers 10 03-30-2018 05:38 AM
Water & Gray Tank Location? Reggie Jones General Chat 9 04-29-2013 11:03 AM
Compact Jr Fresh water tank location? Storm Problem Solving | Owners Helping Owners 4 06-19-2011 10:08 AM
Water tank location? BrendaD Problem Solving | Owners Helping Owners 14 05-07-2009 05:04 PM
