76 Boler Reno/Rework - Fiberglass RV
Old 12-10-2010, 07:07 PM   #1
kgingeri's Avatar
Name: Karl in Elmira ON
Trailer: Boler 1300-76
Hi All,
This will not be a real active thread as I'm doing this reno over the winter in Ontario Canada, but thought I'd start posting a few pics.
My plans are to redo most everything... axles, wheels, brakes (that is in addition to original equip), exterior paint (maybe not til next year), frame (aluminum - see other discussions on this hot topic ;v) and inside too - rebuild cabinets etc, from lighter materials. My objective is to have one of the lightest Bolers around.
So anyway, true to info found in the forums, my Boler had 22 screws, 1 rivet and 6 bolts to get the body off the frame - and that's where I am to date...
Karl *</:v)
(Pics of: frame less body, and inside stripped and washed)
kgingeri is offline   Reply With Quote
Old 12-11-2010, 02:54 PM   #2
kgingeri's Avatar
Some more pics...
Old 12-11-2010, 03:11 PM   #3
Karl this is going to be a fun thread to watch. Thanks for posting the beginning pictures.
Old 12-11-2010, 06:43 PM   #4
kgingeri's Avatar
Thanks Donna.
It sure is a 'project', and is gonna be lots of work - that's for sure!
Karl
Old 12-11-2010, 06:48 PM   #5
kgingeri's Avatar
Here's specs for the new frame and pending cabinets - see attached picture...
Old 12-11-2010, 07:48 PM   #6
james kent's Avatar
Trailer: Boler 1984
There's a lot of people fixing old Bolers are going to love all the measured drawings.
Well done! And, I like the pictures with the baloon statements. Nice touch.
Old 12-11-2010, 08:13 PM   #7
kgingeri's Avatar
Yeah James, I figured I'd share the work. If someone else can benefit, great!!
Mind you, this is a 1976 1300, so I'm not sure how long or for what years it was the same.
I've added (to my working drawing) the wheel spindle measurement at about 41" from inner front edge of floor area (inside, right of doorway). This could vary tho, depending on load and axle degrees etc. My axle seems to be a 10 degree up originally. Also the tabs for body bolts are: 28" to rear nearest edge of 3x3" flange and 13" to the front ones from the same point - inner front floor edge. (they are marked ??" in the above pic)
Karl :v)
Old 12-12-2010, 11:21 AM   #8
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
Karl :v)
I really appreciate the drawings. They will come in handy for my next project, 1971 Boler. Are you planning to replace all of your fiberglass furniture modules with wood cabinetry? What's the condition of your subfloor? I'm keeping a close eye on this thread!
Robert Johans is offline   Reply With Quote
Old 12-12-2010, 02:44 PM   #9
kgingeri's Avatar
Hi Robert,
I haven't settled on just what I'm going to use for cabinet construction yet. It's hard to beat FG for strength and weight!
Thoughts are 1/4" laminated oak and birch - though I'd need 4 sheets (with some waste of course) but I doubt that will be much lighter then the original FG cabinets. Original cabinets are fairly light and made up of about 1/8" FG with 3/4 pieces (strips mostly) of plywood laminated into key areas. Particle board materials are quite heavy for the strength they give, so I'm not convinced there's much value in this method. I'd like a natural wood look, but not the weight. Wood gets even heavier as it takes on moisture - and then starts to discolour, mold or even rot! :v(
Another thought is thin ply panelling, 1/8" but real ply - like mahogany door skins are (vs particle board center - as the laminated oak would be). This would be laminated (via silicon) with coroplast - plastic signboard-like panels (Home Depot carries it in Canada). This is a surprisingly strong combo. I've built a teardrop shell using this method and it has lasted great for 4000+ miles!! It ended up weighting in at 440lbs empty when done (sleeps two - 4' x 7'). Cabinet pieces would be reinforced with either aluminum angle or foam-core lumber strips (also used in my teardrop, and held up great).
Final thought (as of now ;v) is to weld a skeleton frame for each cabinet out of angle aluminum and cover (riveted likely) coroplast laminated with natural oak. You can now weld light aluminum with a propane or MAPP torch using special rods. Our Canadian Tire stores sell them and you can also buy them online. I think this is likely my lightest structure, but there is a fair amount of reinforcing to do to keep cabinet sides from being flimsy. Maybe light panel + coroplast for these areas? It's also the most work!
I haven't finished thinking yet tho. ;vP
I will certainly post pics as I go - ha, for the amusement of all - if for no other reason. ;vD
Another thing I will do is use all stainless hardware and sealant to replace all original rivets that come thru the body. You may think your unit doesn't leak, but check most units in the cabinet seams. The problem with rivets is there is a hole for the crimp pin and unless that is sealed, water can get right through them - or cold air causing condensation. Also over time, and bumps, they can loosen. Look at all the older trailers reno'd and ask yourself why are they so black inside!? Sure some is condensation, if it's kept closed up all fall and spring, but that much?! (If you live in a seasonal environment keep ventilation in it somehow without allowing blowing snow or rain in). When I took my cabinets off, the only moisture I found was around rivet holes - and it was substantial! The previous owner believed it didn't leak - I am sure he was being honest, but during a rain I saw some water coming in. As rivets age, I'm sure this gets worse. I'd be inclined to advise all FB owners to go around their unit with a clear sealer, and do their rivets - in hot weather when they are dry for sure.
As for floor, mine is all fiberglassed and in great shape. It has either one solid pc of 3/4" ply, or strips laminated into it. The main dinette area on mine is laminated strips - about 2" apart and about 2" wide (from what I remember being under it). I don't remember that same corrugated look under the main floor and it is almost on the ground now, so it's hard to check.
Hope that all helps!
EDIT: if using aluminum and the coroplast method, I'd also use aluminum square tubing in the tall closet corners and between the kitchen upper and lower cabinets to give the body the structural strength needed.
EDIT2: changed most of my original "corro-plast" to proper spelling - it should be "Coroplast".
Old 12-12-2010, 09:40 PM   #10
kgingeri's Avatar
Here is a sketch of my proposed layout. This is fairly true to size (other than the tongue). I did an overlay sketch from an original Boler brouchure.
First is the proposed and second is a blank with grid, maybe someone might like to use it for their own 'playing around'...
Karl :v)
Old 12-13-2010, 05:54 AM   #11
Trailer:
From what I understand of your drawings, the front dinette was there when you got the trailer. Did you try it for size?
57" is desparately short for the 'facing' length of a trailer dinette. I tend to regard 66" as the bare minimum and then only when upright seats can be fitted, like in a diner - the higher the seats, the shorter the length a person occupies.
If the dinette is only really intended for one person, or for a couple that are happy to sit at a slant with their legs not under the table, then I can see this size might work.
Andrew Gibbens is offline   Reply With Quote
Old 12-13-2010, 06:53 AM   #12
I have to agree with Andrew. The dinette appears to be too small for comfort. I'd layout tape on the floor and see if you can sit there. You may find the table needs to be a whole lot smaller and your knees are more than just touching comfortably. Love the CAD! It's nice to see visuals:
Old 12-13-2010, 10:53 AM   #13
kgingeri's Avatar
Yeah, you guys are right. It is too small for sitting with legs 'under' - at least two people. I did measure it out and try it. We'd likely do as you suggested Andrew - sit facing the bed.
I debated leaving a bench and having some kind of fold-down or portable table between, but thought this way one person could use it sitting with legs under. I tend to 'nerd' a lot (use my computer) when we camp, so I'd be the biggest user. We are both a shorter couple - 5'3" and 5'4" so that helps too.
I may need cushions across the front as well tho.
Old 12-13-2010, 02:43 PM   #14
Maybe something like this would work? Worldwide Merchandise Company - Oak-finish Wall Table - Tables - Camping World You may need to fabricate it to make it narrow enough....
Old 12-13-2010, 02:57 PM   #15
kgingeri's Avatar
Hmmm, likely a bit heavy Donna, but I love the site!! Great resource!
(I'm watching every pound I can, practically)
Old 12-13-2010, 03:04 PM   #16
kgingeri's Avatar
One thought was to partition the back cushion in the middle to fold-down between us - like some cars have in the back seats. That is to say a table surface that the cushion is attached to (hinged at the bottom, folding out at the top). The problem is that for 'nerding', it's not comfy to work with your back twisted like that for long! :O Hense the need to use it with leg room.
Mary (my wife) would like to have the bed always made, but use pillow-like cushions around the walls for sitting, if need be. Still considering options as there is no rush
MOstly I 'nerd' outside anyway, this is only when weather doesn't co-operate with our camping schedule
Old 12-13-2010, 10:49 PM   #17
Trailer: 13' Boler 1977
hey, i have a question about taking the body off the frame, .......
are you walking/working on the shell while it is sitting on the ground?, did you put any supports under it while walking around in it?, ...
I want to do this to my 73 boler this spring, but only have a small garage and would love to put the shell in it to work on it, (it won't fit in the garage on the frame) but was wondering if i would wreck something with nothing supporting it while it is on the ground and off the frame........???hope you understand my question
thanks
Paul
pbraunton is offline   Reply With Quote
Old 12-14-2010, 06:28 AM   #18
Paul parts of the body are lower than the frame. The body sorta wraps around the frame. You'll need to support it from the bottom so you don't crush those parts.
Old 12-14-2010, 08:15 AM   #19
kgingeri's Avatar
...snipped...
Paul
Hi Paul,
Donna is correct. I have mine supported in four corners around the outside of the floor area - where there is laminated plywood in the FG. This means my floor is suspended off the ground by a few inches (thought that'd be better as it is outside). I could likely slide some 2x4's under the floor area yet as well for a bit more support.
So yes, I am working in it. I don't think you want to jump up and down while in there, as there is no metal support around the immediate floor area. If you shim yours up with the FG floor resting slightly on the garage floor (ideal), you'd be all set to dance in it
Karl
EDIT: if you look under, you should find the areas where plywood is laminated in the FG.
Old 12-14-2010, 09:04 AM   #20
Trailer: Casita 16'
Wisconsin
Lightweight door panels
kgingeri,
I'm having the interior re-done on a 1990 Casita. Alumalite is the material that is being used to make new cabinet doors. Checkout this website to give you some ideas. aeroparadise.com
Good Luck, Mona
monasimpson is offline   Reply With Quote
boler
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
Compact Jr. Winter rework session Steve Hilby Modifications, Alterations and Updates 59 03-10-2012 08:35 PM
BOLER RENO - 17' - Not bad for a newbie! Dawn S Modifications, Alterations and Updates 20 09-06-2009 12:50 AM
Boler Reno pics David Konduc Modifications, Alterations and Updates 1 08-20-2009 05:57 PM
Sis' Compact Jr Rework Fall 08 Steve Hilby Modifications, Alterations and Updates 8 11-07-2008 09:12 AM
