Primer layer on our Boler - Fiberglass RV
Old 02-15-2022, 08:25 PM   #1
Hi guys,
We applied 1 layer of Interlux Pre-Kote primer on our Boler so far, and the finish came up great.
We did not use any thinner, and it did not seem to have any negative effect.
Before applying the second coat, I just want be sure that there is no major issue with not using thinner.
Please advise.
Niall
Niall is offline   Reply With Quote
Old 02-20-2022, 05:34 PM   #2
Trailer: Trail Cruiser
Thinner, as the name applies, is intended to dilute the primer and is usually required for spray application as it is too thick to spray otherwise. Other means of application, brush or roller, you may not need to thin it down but it should still work. There will however be much sanding involved.
Mike_L is offline   Reply With Quote
boler
What is this? Layer under headliner Dax Problem Solving | Owners Helping Owners 1 05-17-2021 05:03 AM
Is gelcoat layer needed to make fg waterproof? mglyons Problem Solving | Owners Helping Owners 10 11-10-2015 08:08 PM
What a difference a coat of primer makes! courtney Modifications, Alterations and Updates 15 09-05-2013 08:13 PM
flat black primer Lee Trenholm Care and Feeding of Molded Fiberglass Trailers 10 05-06-2008 10:36 PM
Insurance Primer for Newbies Needed Legacy Posts Problem Solving | Owners Helping Owners 23 06-24-2003 01:54 PM
