My 17ft
Boler (1700) does not have the traditional ensulite insulation that most 13ft Bolers have. Attached are some images of the product. My best guess is that it appears to be a foam base with a sprayed-on-white bubbly texture. Another 17ft
Boler I saw last weekend had the same product for insulation, so its from the factory.
The liner is unglueing in some places and I would like to address this issue.
- Can someone confirm the material type? is it polyurethane foam? Photos included.
- I'm no chemist. What should I use to bond the insulation material to the fibreglass that can withstand summer's heat and mild winter (-10c to +40c ish)? Contact cement doesn't like polyurethane. An experienced person's opinion would be appreciated.
- If you know the material, what should I use for
paint touchups? I suspect something breathable?
Looking forward to your replies.
