Surfside interior seam trim ? - Fiberglass RV
Old 05-05-2011, 07:35 PM   #1
serious sam's Avatar
Trailer: Triple E surfside
Hi
I am looking for the interior trim that covers the seams on my surfside, does anyone know where to find some in Canada
thanks for any help
serious sam is offline   Reply With Quote
Old 05-05-2011, 08:49 PM   #2
Trailer: 1974 Trillium 1300
Hi Sam, Do you still have the old stuff? Ours was all wrinkled, crinkled and covered with gunk. We thought it was a complete loss. Then I read here somewhere about boiling it. I got out our canning pot and gave it a crack. They came out as clean and flat as... well I'm sure better than new. You might want to give it a try.
Dan
bastiaad is offline   Reply With Quote
Old 05-06-2011, 04:52 AM   #3
thanks for your input, but it no longer has the original molding.
The previous owner put this duct tape looking stuff up and now
it is pretty much falling off
Old 05-06-2011, 09:04 AM   #4
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
Would some kind of floor trim work?
Maybe like these 2 kinds.
Kevin K is offline   Reply With Quote
Old 05-11-2011, 10:22 AM   #5
thanks for your suggestions , I ended up ordering some foam tape off ebay.
I hope it will work
5m White Single Sided Foam Tape 20mm Wide x 3mm Thick - eBay (item 270741117028 end time May-26-11 11:29:58 PDT)
Old 08-06-2013, 06:34 AM   #6
Trailer: SurfSide
Saskatchewan
Question
I just came across your post and was hoping to find out how this project went for you.
I just purchased a "77 Surfside and most of the seam tape is gone. i want to replace it. and was wondering about what type of tape to use and how to prepare the surface for application (removing the old adhesive residue - I want to be sure I don't damage the existing wall covering).
Terry Was is offline   Reply With Quote
Old 08-06-2013, 06:46 AM   #7
the tape I got off ebay wasn't wide enough, so I ended up getting a textured vinyl close to same color and texture of walls and cut the material into about inch and a half strips.l then used contact cement to glue them onto seams , I just left old residue on seams as it would have been too much work removing
hope that helps
Old 08-10-2013, 08:17 PM   #8
Trailer: Triple E
Hey Terry, have you seen this post: http://www.fiberglassrv.com/forums/f...one-46383.html ?
I'm in a similar situation and am planning on going this route.
kellyben is offline   Reply With Quote
Old 08-10-2013, 08:26 PM   #9
jrocmagoo's Avatar
Trailer: 1978 Tripple E Surfside
Check out my surfside build thread,i used paintable caulking and a damp sponge, sealed it nice and painted over it,i couldn't imagine doing the tape
jrocmagoo is offline   Reply With Quote
Old 08-13-2013, 04:21 PM   #10
Trailer: Surfside
I did the same thing in my SurfSide. I used paintable elastomeric caulking and a textured roller. I filled the gaps with caulking and then rolled it. After it dried I painted the entire interior. It turned out OK and better than seams that the previous owner had filled with every possible product.
Keith P is offline   Reply With Quote
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Surf Side- interior wooden window trim Jason, M Problem Solving | Owners Helping Owners 5 08-03-2008 12:31 PM
Seam Tape Jason, M Care and Feeding of Molded Fiberglass Trailers 2 07-07-2008 06:14 PM
Seam Tape John L. Problem Solving | Owners Helping Owners 16 07-02-2007 08:08 PM
Interior covering -- Surfside Sandy Gilpin Care and Feeding of Molded Fiberglass Trailers 13 12-07-2005 11:51 PM
