Bigfoot 25 RQ Water Pressure - Fiberglass RV
Old 12-26-2018, 05:37 PM   #1
Trailer: Bigfoot 25RQ
Mississippi
So far we really enjoy our new bigfoot. My wife does complain about the lack of water pressure in our shower though, sinks are fine just lower flow to the shower/ Anyone else see this on a newer 25RQ?
snuffy2 is offline   Reply With Quote
Old 12-26-2018, 07:02 PM   #2
Bruce H's Avatar
Happened in mine. It was the shower head not open all the way.
Bruce H is offline   Reply With Quote
Old 12-26-2018, 08:26 PM   #3
Name: Bruce & Kathryn
Trailer: Bigfoot 25 RQ
Are you using city water or the water pump? We get great shower water pressure from the pump, but often not so much when hooked up to the campground water.
“Tomato Man”
Buce, Kathryn & Oscar the pug
Bigfoot 25 RQ
Towed by 2018 Chevy High Country Duramax
Bruce Olive is offline   Reply With Quote
Old 12-27-2018, 06:56 AM   #4
Mississippi
Shower
It's full open and it doesn't matter if we are using well water or city water. When we use community water we use a pressure regulator to keep it at 50 psi. Our pump runs it at 50 psi and kicks on at 40 psi.
For me the pressure isn't an issue since I now have more hair on my back than my head. My wife on the other hand very, very thick long hair, complains it takes soooooo long to wash and rinse.
Old 12-27-2018, 07:08 AM   #5
Seems like ours happens on city water but not on pump. OK for me, but wife notices these things. Wonder if one of those low flow eco-shower heads would present a better spray pattern? I might try that.
Old 12-27-2018, 07:13 AM   #6
Mississippi
Trip
This next trip maybe I should give her a hand washing her hair!
Old 01-02-2019, 01:20 PM   #7
Nevada
Shower Pressure
We have a 2017 25RQ and had the same issue. We put on an oxygenics shower head we got from Amazon. Made a world of difference with increased pressure and uses less water. We also switched the outside shower head.
Nvboatman is offline   Reply With Quote
Old 01-03-2019, 01:41 PM   #8
Mississippi
Shower Head
Do you have a model number, that link opens to many shower heads!
Old 01-03-2019, 04:50 PM   #9
Nevada
Shower head
On Amazon
ETL 26781 Oxygenics hand held sprayer kit. $33.31
Old 01-03-2019, 05:22 PM   #10
Name: John & Gloria
Trailer: Bigfoot 21RB
Snuffy, A lot of the OEM shower wands have a restrictor in the line. Just unscrew the wand from the hose and you will see what looks like a washer with a small hole in it. Remove it and screw the wand back on and it should wake up that wimpy shower head. Don't throw the washer/restrictor away in case you spend some time boondocking where you need to be stingy with water.
Travelin2 is offline   Reply With Quote
Old 01-05-2019, 02:10 PM   #11
We have a Oyxgenics shower head. Makes all the difference in the world.
Simple solution.
JimKE is offline   Reply With Quote
bigfoot
Hot water tank pressure release valve Steve Nentwig Problem Solving | Owners Helping Owners 3 04-08-2007 04:38 AM
water pressure regulator Chris Z Problem Solving | Owners Helping Owners 9 07-05-2006 02:55 PM
Water Pressure Regulator jefh Care and Feeding of Molded Fiberglass Trailers 10 01-31-2006 08:26 PM
Water Pressure Accumulator Steve L. Modifications, Alterations and Updates 2 11-24-2005 04:32 PM
Water Pressure Accumulator Legacy Posts Modifications, Alterations and Updates 19 03-19-2003 08:24 PM
