Can it be done? roof modification on an egg - Page 2 - Fiberglass RV
Old 02-13-2003, 07:11 PM   #21
If you take a good look at how thick your fiberglass is , it makes you think.Less than a 1/4":conf
Legacy Posts is offline   Reply With Quote
Old 02-14-2003, 07:55 AM   #22
When did they reinforce it?
My question is, what year did Scamp upgrade the roof to be stronger?
Jamie -- the problem, I think, with older eggs is that the roof doesn't have enough arch to make it strong. It's relatively flat and thin. Thin is ok if there is sufficient arch. However, the walls, being vertical, and the edges of the roof, being tightly arched, should be plenty strong. What you are proposing is to actually remove the weakest part of the roof, and replace it with a proven-strong roof. This new roof will be sitting atop the strongest areas of the existing camper. Don't mistake me for an engineer, but I think if anything, you'd have a stronger roof. My bigger concern would be the increased flex at the corners. When you cut the hole, allow sufficient radius at the corners so they don't flex and crack. And again, by glassing up a lip at the top for the Westie top to fit over, you'll be further stiffening it, both for snow load and flex. I don't want anyone to say, "Well, Paul told me it would work", but I think it should.
Old 02-14-2003, 09:14 AM   #23
Paul,
I have to look at The Love Bug closely this weekend. Here are some pictures that you can see the roof line.
<img src=http://www.fiberglassrv.com/board/uploads/3e4d078420a4fleftrear.jpg/> <img src=http://www.fiberglassrv.com/board/uploads/3e4d07c4dbd06rearshot.jpg/>
Any one know where I can find round taillights like what is pictured? They are surface mounted.
Old 02-14-2003, 09:31 AM   #24
misc
tail lights:
I seem to remember hearing they were the same as used on school busses of that era. Certainly no shortage of those things. Might be worth a peek.
mkw
Old 02-16-2003, 10:01 AM   #25
Pop top
Jamie,
I love your concept, it looks great! A little structural analysis will show you that your idea can be safely and easily accomplished. For those tail light lenses, I wonder if you can get a piece of red lexan or plexiglass and heat it in an oven over a wooden form.
Good luck,
Rick D.
'78 Boler 1300
eggcamper
New Modification To C-J Jeff_Miller Modifications, Alterations and Updates 32 06-19-2007 05:35 PM
bunkbed modification Ginni Modifications, Alterations and Updates 7 06-28-2006 09:31 PM
Frivolous Modification Byron Kinnaman Modifications, Alterations and Updates 16 04-20-2006 03:17 PM
new tug modification Joe MacDonald Modifications, Alterations and Updates 9 01-19-2006 04:42 PM
Modification Legacy Posts Problem Solving | Owners Helping Owners 5 10-27-2002 07:18 PM
