In January this year we bought a 2001
Casita 17' Spirit Deluxe, in excellent used condition (except for a lingering old cigarette smoke odor which I've nearly solved, I think).The trailer did not have a
battery installed but the seller provided me with a supposedly new automotive type
battery. When I got home the 'new'
battery was discharged & would not take a charge. I had on hand a nearly new (less than a year old) Duralast group 27 'deep cycle' battery which I installed in the trailer. The
Casita has a battery compartment, accessed from the outside, on the street side at the rear of the trailer. The compartment will accept probably a group 31 battery but it'll be 'tight'. Battery is held in place with a couple of pieces of aluminum angle bolted thru the floor, with a piece of wood 2X4 fastened to the upper rear of the compartment, apparently to prevent the battery from bouncing? Also, it has a radius access door with the bottom of the door approx 1.5" higher than the compartment floor, & lemme tell ya it's a real 'bear' trying to 'manhandle' a battery that weighs a third as much as me, into that little opening. I'd seen other Casitas with a 'slideout' battery tray, & determined that's what I needed. I considered relocating he battery to a box on the tongue but I kinda like the idea of a battery in its own locked, weatherproof compartment.
Casita doesn't supply or market such (tho apparently the newer models do have an aluminum base & tray that approximates the height of the access door opening. I searched the internet & a couple of Casita forums for ideas, tips, & pix of a slideout battery tray that I could fabricate using a minimum of tools. I don't have access to or skills to use a TIG or aluminum welder so a tray I could build with mostly hand tools was important, as was cost involved. Finally found a partial PDF from the CasitaClub forum (the narrative & some pix were there but some dimensions & hole placement was missing). I was able to 'extrapolate' the missing information using the dimensions of materials called for, & fabricated a slide out battery tray made entirely of 'off the shelf' aluminum flats & angle & 'pop rivets', along with 100# drawer slides from a 'big box' store locally. The drawer slides must be mounted 'flat' in order to work in the compartment, & if I'd known how 'weak' they are when mounted flat, I'd have ordered a set of 200# slides. The ones I used hold up pretty well but when I have the tray fully extended with the battery in place, I use a spare 'pyramid' type trailer stabilizer as a brace just in case. I still need to devise some kind of 'hold down' to keep the battery from moving while the trailer is under way. The compartment is small enough, with enough 'stuff' in there that the battery cannot possibly 'tip over' but I'd feel more comfortable with at least a poly or cordura strap to help hold it down. I'm currently working on that... I had to 'notch' the lip of the door opening at bottom to accomodate the tray, but it doesn't affect the
weatherproofing of the door.
Here's a few pix - first the access door, a pic of the battery in place before building the tray, various shots of the material & building the tray, & finally the tray in place, battery cut-off switch, a bolt I installed to keep the tray from 'banging' against the door, & a 'loop' I made to pull the tray out for service
