Casita gray & black tanks. - Fiberglass RV
Old 01-23-2020, 04:45 PM   #1
Question Casita gray & black tanks.
I am staying in Wawona for the winter as a volunteer. I need to go home next Mon-Wed. The temp on the 2 nights is projected to be 35 degrees. Should I put anti-freeze in the black & gray tanks after removing all the water? I have a skirt around the bottom of the trailer and a 700 watt heater underneath. I am concerned about leaving any heat source on for the two days I’m away. So far the temp under the trailer has never been below 36 degrees, but I use a propane heater on a thermostat or a space heater when I’m there. The temp during the days is in the 50’s and at night high 30’s to low 40’s at night. Thanks!
Lorijoan is offline   Reply With Quote
Old 01-23-2020, 07:20 PM   #2
NW Wisconsin
I would not be concerned at 35 deg or at 32 deg for that matter nor would I spend the money on antifreeze . Your plumbing is not going to freeze and damage anything
We are experiencing temps in the low 30’s up here in the North which is referred to as a heat wave
Well heading back outside to enjoy the nice weather and shovel some snow .
Old 01-23-2020, 09:32 PM   #3
For my peace of mind I would disconnect the water hose, if there is one, push in the check valve at the hose connection with the faucets open to drain some water out of the lines. I would dump some RV antifreeze in the sink traps and drain the gray tank. Don't leave the dump valves open if connected to sewer. I do agree with Steve that you probably have nothing to worry about, but the weather can change unexpectedly. RV antifreeze is cheap.
Old 01-24-2020, 05:22 PM   #4
Thank you that’s a great help!
Old 01-24-2020, 05:23 PM   #5
Thank you!
Old 01-26-2020, 08:06 PM   #6
charliej's Avatar
Trailer: 2002 16 ft Scamp
DO NOT push in the check valve at the city water connection on your trailer. This will ruin it and make it inoperable.
charliej is offline   Reply With Quote
Old 01-27-2020, 06:44 AM   #7
Can you advise of any documentation to support this statement?
With the pump off, as long as you don't dislodge or damage the O-ring I fail to see how pushing in the check valve will damage it. After all, when you hook up a hose the water pressure pushes it in all the time. Of course if you jam a ice pick or something like that in you probably will damage the sealing O-ring, but pushing in the plastic center with a finger should be OK. Lots of people do this to get water in the line to drain (where the capillary action would otherwise leave water in the line near the valve or in the valve). Others use air pressure to do the same thing, and that pushes in the valve also.
Old 01-27-2020, 11:06 AM   #8
charliej's Avatar
Gordan, you are correct. The concern is using something that dislodges or damages that o-ring. It must be done correctly.
Old 01-27-2020, 11:12 AM   #9
Gordan [actually Gordon, ed.], you are correct. The concern is using something that dislodges or damages that o-ring. It must be done correctly.
OK thanks for the clarification.
casita
Grey & Black tanks Rog Mich General Chat 9 06-09-2017 05:04 PM
Combining Gray & Black Tanks Bster13 Modifications, Alterations and Updates 14 08-07-2015 10:27 AM
help! clueless about dumping gray and black water tanks joy mccalla Care and Feeding of Molded Fiberglass Trailers 12 04-18-2010 08:13 PM
17' Boler Black and Gray water tank size kevin61 Care and Feeding of Molded Fiberglass Trailers 1 08-30-2009 11:09 PM
Gray/Black water sensors don't work Legacy Posts Problem Solving | Owners Helping Owners 9 08-11-2003 09:28 AM
