Originally Posted by Nancy.
How is the awning rail attached to your camper. Does it show through on the inside ceiling or wall?
There are a number of ways to attach an awning, depending on its type, size, and
weight.
For a smaller, removable awning, I'd use 3M VHB tape to attach the rail. For a larger awning or a bag awning you will leave attached for towing, I'd use the tape plus a few aluminum rivets for additional strength. The rivets might make a small bump in the rat fur. Apply a dab of sealant just before you pull each rivet.
For a heavier, rigid case awning, I'd use SS bolts with fender washers for the mounting brackets. You can make slits in the lining to install and glue it back for a neat appearance. In addition to a dab of sealant, apply non-permanent thread locking compound if it's going to be a hidden installation.
