Originally Posted by Delight in CO
At least now I know that a 16' is too small for me.
That is good to know, but it opens the question of how big is big enough?
Molded fiberglass trailers in general are very compact, many are narrower than conventional stick-built trailers, and all make various compromises to be the small, lightweight alternative. Sizes can be misleading because molded trailers follow the older convention of designating models by overall length (tongue-to-bumper). The cabin length is typically about 3' less. Non-molded trailers usually designated their models by cabin length, so a 16' Casita is comparable in size to a 13' conventional trailer.
Curious what aspects of the trailer felt too small? The biggest compromises in a Casita 16’er include the main bed size (at only 45” wide), the galley (with no counter space), ceiling height (at 5’10”), and the small
fridge. Compared to a 16'
Scamp, owners of both have commented that the Casita aisle is narrower because the cabinets are deeper. A
Scamp also has more headroom, at around 6'2", but the same narrow rear bed (unless you spring for a deluxe wood-interior version, which gets a wider 54" bed).
A 17’ Casita addresses all the shortcomings except the galley, but it requires an upgrade in tow vehicle capacity due to its significantly higher tongue
weight. A 17’
Escape has similar functionality, but some people find it feels roomier due to a different layout that includes a large front window.
Bigfoot also makes a 17’ model with several layouts. It’s wider and boxier, so it will also feel roomier, but it is a harder tow requiring a more robust vehicle. Beds are still pretty narrow. Newer ones (listed as 17.5’) are winter-rated and significantly heavier.
Next step up in size are the 19’ and 21’ models from
Escape. Either will likely require a significant increase in budget. There’s also the 19’
Lil Snoozy, which has a very open layout. Downside is it’s all-electric and not set up for off-grid use,. Some owners add the
propane systems after purchase.
Just throwing out some molded fiberglass options to watch for. As you have found, there is no substitute for getting inside a real, live trailer.
For us, our 13'
Scamp (10' cabin) is perfect for four people. First, many people have said you don't live
in a small RV, you live
out of it. That's us. We don't spend much time with all four of us inside the trailer at once unless we're sleeping. Second, having a lot of
windows can increase the
feeling of spaciousness, even if it doesn't actually make it bigger. Third, we learned some tricks here on the forum to make a small space work harder. For example, we sleep head-to-toe in separate tapered sleeping bags to make the most of the narrow rear bed.
