Originally Posted by mary and bob
Some new Casita owners go directly from their pick up at the factory to Little Home on the Road to get the shock kit installed and other modifications that they offer. Check with them for an appointment after your pick up date. Comments seem to be all positive about their services and modifications.
This is true. We went back the following year after making a list from asking folks on the site. You use their calendar to set up a day you can be there. My advice would be to talk to them & ask if you need to schedule one or two days for the work. We had too much work for one day & had to cancel a couple of items. We had the shocks put on. Stuff is still going to bounce around. Your curtains may still
fall. ( we fixed this with safety pins )
So it doesn't work as a car shock. But I do feel like they helped because we ended up going on some rough roads.
3-Way
Porch Light switch Turn your outside
light on or off from inside or outside the trailer
We had upgraded jacks added on. They are great because I had tire problems and you can use the jack to lift the trailer to change a tire.
Light for hot water heater & water pump installed.
Fridge door supports.
Front Cargo Carrier Stromberg Carlson tongue-mounted tray.
The city Fort Worth is an awesome place to visit.
Let us know what you do.
