We have a 2010
Casita Spirit Deluxe that we've owned for a couple years but only recently started using the plumbing. We're preparing for an extended summer road trip and having an issue with the hot water heater using
propane.
The unit is firing up on
propane and running for about 5 minutes. Once the unit cycles off I turn the hot water on at the sink faucet and it will warm up to lukewarm for about 20 seconds then revert back to the temperature of the source water.
Unit does not fire up again unless you toggle the on/off switch on the cabinet of below the dinette.
Would appreciate any suggestions or additional troubleshooting steps.
Couple additional notes -
Using city water connection not onboard tanks.
water heater bypass valve is open
propane tanks are full
I have not attempted to heat using the electric option as I plan to check the anode condition
