Trillium 5500 tail lights - Fiberglass RV
Old 11-07-2019, 08:43 AM   #1
Trailer: Trillium 5500
Canada
good morning I'm new to the forum & new owner of a 1980 trillium 5500. I need to replace tail lights & want to install led turn signals & brake lights. is there a specific brand to buy from lordco or princess auto for the guts?
Shanti 5500 is offline   Reply With Quote
Old 11-08-2019, 06:52 PM   #2
Hi. I replaced the rear lights on my Boler using a set of 7 inch diameter LED’s from Princess Auto. They covered the old area perfectly. Not sure what the lights are like on your Trillium but I think you would be happy with the LED replacement. Doug
DougBu is offline   Reply With Quote
Old 11-09-2019, 07:36 AM   #3
Carl V's Avatar
The triple tail lights of the 5500 are called "Grote 51342", or "Monarch 4.25" triple lights. Common on many Airstream trailers for some time, with slightly different housings and color (the lens and internals are the same).
You might want to Google "Grote 51342 LED conversion" or similar key words.
Here are a couple links I quickly found:
Sealed LED light kit for old 4.25 Monarch LED-kit2 [LED-kit2] - $179.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
LED Tail Light Kit for 4.25 Monarch Airstream
For some reason my 5500 has double Monarch lights instead of the triple I've seen on every other 5500. Not sure why.
In any case, here's how I converted mine to LED: I bought some red SMD leds (larger ones for the stop/turn, smaller ones for running light) and wired them to 1157 bulb bases. Stuck the SMD inside the housing with 3M double face tape. Works perfectly, they are pretty bright, and I can go back to regular bulbs if I need to. For the backup lights I simply replaced the regular 1156 bulbs with some white 1156 LED.
Also, I invite you to list your 5500 on the Trillium 5500 Registry. All you need is you serial number.
https://airtable.com/shr4bWwL6yN2zjyAD
https://airtable.com/shrJg5Nd0S13LxN2A
light, lights, tail lights, trillium
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
On (Canada) - 1981 - Trillium 5500 - $5500 David Tilston Referrals: Molded Fiberglass Trailers 4 10-13-2014 11:09 AM
WA Trillium 5500 $5500 kootenaigirl Referrals: Molded Fiberglass Trailers 6 09-05-2014 09:59 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
