Removing Solar Panel on Uhaul - Fiberglass RV
Old 10-25-2009, 08:44 AM   #1
Judith Kennedy's Avatar
Trailer: 1984 U-Haul
I am attempting to remove the solar panel on my uhaul.
The screws underneath have large diameter heads on them with straight screwdriver slots. The slots are so shallow that there is no way a screrwdriver can get a grip on them. They look like they are aluminum, but my attempt to drill them out revealed that they were hard as a -------- ( insert your own phrsase ).
Anyone have any ideas?
Judith Kennedy is offline   Reply With Quote
Old 10-25-2009, 08:48 AM   #2
Gina D.'s Avatar
Easy Outs
Old 10-25-2009, 09:10 AM   #3
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Over on uhaulcamper.com, they say to access the screws through the ceiling carpet.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
Old 10-25-2009, 09:31 AM   #4
Trailer: 2009 Scamp 16 ft / 2003 Durango
If you can get a hacksaw blade in the slot, make it deeper. Or maybe a Dremel blade.
Bill K
Bill K is offline   Reply With Quote
Old 10-25-2009, 10:08 AM   #5
Flygal's Avatar
Trailer: 77 Scamp
could be an aluminum post where its just spinning when you drill it. Like the poster befor me said you may need to access inside and also have someone up top twisting the opposite direction or at least having some form of tension to keep it from spinning. here is a photo of what i think it is your describing
Flygal is offline   Reply With Quote
Old 10-25-2009, 11:47 AM   #6
O.K. I found the answer.
First of all the screws are flat head and flush.
Secondly, the screw threads on the other side of the fixed nuts were corroded so that I would not have been able to remove them even if I could get a purchase on the head.
So---- I removed the ends of the frame, cut the wire, and slid the unit out of the frame rails. This exposed the end of the bolts. Then I cut the nuts and bolts all together with an angle grinder.
What a job!
Old 10-25-2009, 12:39 PM   #7
Bruce Thomas's Avatar
Trailer: U-Haul CT13
why did you remove it?...do you have pictures of how it mounts etc?.I have my panel but no bracket for it so Im curious.....Bruce
Bruce Thomas is offline   Reply With Quote
Old 10-25-2009, 01:04 PM   #8
The panel fits into a channel on both sides. The aluminum channel has six 1/4 - 20 nuts mounted perminantly on the lower channel legs. The six screws thread into the nuts from below.
Old 10-25-2009, 01:05 PM   #9
Oh, I forgot to mention, the panel only put out 3 volts. I suspect it is trash.
Old 11-01-2009, 07:43 PM   #10
Pam Garlow's Avatar
Trailer: U-Haul 1985
Check out the Uhaul manuals posted on this site. They explain the solar panel (and a lot of other things). The panel is not meant to charge or keep a full charge on the battery. According to the repair manual (pg 14) it was meant to keep down battery sulphation (whatever that is ) while the trailer was on their rental lot. If you are maintaining your battery's charge, then the panel is not really not needed
Pam Garlow is offline   Reply With Quote
Old 11-01-2009, 07:58 PM   #11
You learn something everyday! I thought the purpose was to keep the battery charged. How would this be accomplished? Our VT didn't have a battery when we bought it, so I haven't hooked one up. What would do the charging?
Old 11-03-2009, 07:17 PM   #12
Pam Garlow's Avatar
My Uhaul has a converter that charges the battery when the trailer is plugged into shore power.
Old 01-15-2023, 07:32 AM   #13
Trailer: Uhaul CT-13
Removing leaky solar panel
What a job!
I had my dad help remove mine this weekend and your post really saved us some time thinking through everything. Here are some pictures for future users.
F136859E-95CA-46B4-87E7-2F8EB301800B.jpg   FF67C6CE-B589-40FE-9AE0-CD83284693FB.jpg
BFB314B3-D8E9-47A2-844A-347B74C1AADE.jpg   9369FE04-FC16-422F-978A-B1C4764F5EC6.jpg
Agent_Oswin is offline   Reply With Quote
Old 01-16-2023, 01:05 AM   #14
Trailer: Owner of a 16' fixer Scamp and fixed up 13'
Nice work.
Pretty amazing that a 14 year old post is still helpful
funkgun is offline   Reply With Quote
Old 01-16-2023, 02:08 PM   #15
David Tilston's Avatar
Originally Posted by funkgun View Post
Nice work. Pretty amazing that a 14 year old post is still helpful
The post may be 14 years old, but the trailer is 39 years old. I like to think that we are recording history here.
Old 01-18-2023, 12:15 PM   #16
True, and mine is 44 years old as well. However, look at uhaulcamper.com, it is no longer a site, but a side note in the facebook group link.
Time is kinder to our trailers relevancy than to the internet equivalent.
solar, solar panel, u-haul, uhaul
solar panel on Uhaul 13 CT Marty D Problem Solving | Owners Helping Owners 1 06-16-2010 04:49 AM
solar panel Judith Kennedy Problem Solving | Owners Helping Owners 2 10-29-2009 11:30 AM
Solar Panel Location Fred Modifications, Alterations and Updates 8 01-17-2007 10:26 PM
solar panel help Maggie Electrical | Charging, Systems, Solar and Generators 9 07-18-2006 04:38 PM
Canadian Solar Panel Barbara Gardin Electrical | Charging, Systems, Solar and Generators 5 04-01-2006 07:34 PM
