Originally Posted by Mike Meyer
Don’t think that the PD 4045 will completely charge Lithium Iron phosphate batteries doesn’t have the special voltage output to top them off
Yes I believe it does. It should have a changeable pendant just for Li batteries. I recently purchased a PD4635 VL, the “V” denotes and “L” denotes Lithium. Not 100% positive about the PD4045 model but it “should” have the same VL designation.
But as @gordon2 posted not necessary…….
From the Progressive Dynamics website
“ PD4000 Series Features
Switch selects between Lead Acid and Lithium Batteries.
Compact & lightweight.
Reverse battery protection with easy to replace fuses.
Electronic current limiting.
High and low AC input protection.
Intelligent, variable speed, cooling fan.
Automatic thermal protection.
Front access to large wiring compartment.
Snap-lock cover stays shut while traveling – opens with a touch.
Attractive lightweight panel design made from black impact-resistant high temperature polymers.
Covered by one or more of the following U.S. Patents: 7,782,002 and RE39,461.”
