New Boler owner - Fiberglass RV
Old 05-20-2021, 12:25 AM   #1
Trailer: 1976 Boler 17
New Boler owner
Hi everyone my wife Ann and myself (Brad) just purchased a 1977 17 ft trailer in need of a lot of work , we are getting to the end of the inside Reno and now I’m focusing on the windows, but don’t even know where to start.in it’s life it has had all replaced with plexiglass,and very poorly siliconed into the frame, what a mess . I need any advice I can get on rebuilding the windows . Can you even get the rubber that holds the glass in anymore or do you have to silicone it back into the frame
Mrwbhall is offline   Reply With Quote
Old 05-20-2021, 06:17 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Brad, the Boler 17 window seals / gaskets are still available. See the following thread from a few months ago for details:
EDIT (fixed link):
https://www.fiberglassrv.com/forums/...als-92972.html
I recommend you remove all of the windows from the trailer in order to re-apply butyl tape to the back of the window flanges, as this is a common source of leaks.
The 70 feet of 1/8" glass glazing bead (H009-344) around each pane of glass does NOT actually seal the glass, but it covers the sharp edge of the glass, keeps dirt out and helps hold the glass in. What really holds the glass? Where the back edge of the glass pane rests in the frame, either 1/4" wide butyl tape or 1/4" wide polyurethane glazing tape or glazing silicone is applied.
But first the frame must be completely cleaned and all previous sealants removed...
Good luck with your project! You will enjoy the results.
Old 05-20-2021, 08:07 AM   #3
Smile Glass glazing bead
Thanks so much John that link just put a huge smile on my face .I had looked and looked and talked to window people here in town and they told me it wasn't available any longer. so again thankyou thankyou thankyou
Old 05-20-2021, 10:07 AM   #4
oops I posted the wrong link...
just fixed the link above
Old 06-04-2021, 07:16 PM   #5
Borden's Avatar
Name: Borden and Carole
We re-did ours the local glass place cut the needed replacements panes. They were regular glass with edges rounded and little plastic spacers; just like original. Ours is 1978 with Hehr radius windows but you may have the older Jelousie windows or a mix. Pictures of windows helps.
Our postage stamp in heaven.
Borden is offline   Reply With Quote
boler
New member New boler owner cadmodel Problem Solving | Owners Helping Owners 5 07-24-2016 01:55 AM
Hi! I'm a new user and new to me 1979 Boler 1700RG owner BolerBee Hi, I am.... 8 05-24-2016 09:01 AM
New to this forum and new owner of Boler Tvessels Hi, I am.... 13 10-17-2013 06:58 PM
New Surf Side owner looking for owner's manual Lake Surfer Problem Solving | Owners Helping Owners 3 06-14-2012 08:49 PM
New old owner, or old new owner? drews60 General Chat 7 11-17-2006 05:36 PM
