Boler interior insulation seams - removing silicone - Fiberglass RV
Old 05-29-2021, 09:48 AM   #1
Hi there,
So the previous owner of my Boler jammed all of the interior seams of the Ensolite with silicone caulking - feathered out up to an inch or two wide in some places. No primer will stick to it and as a result the previous owner’s paint job has chipped away at all of the seams. Removing the silicone seems ridiculously daunting. The interior looks pretty terrible with the unpainted silicone exposed.
Would it be ridiculous to cut a 2” strip out at every seam joint and then replace with a 2” strip of something else? Recommendations for “something else” appreciated.
Also appreciated are other possible solutions to render my interior paintable.
Thanks in advance!
Karen
Special-Karen is offline   Reply With Quote
Old 06-01-2021, 09:13 AM   #2
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Cover the silicone with tape or something else and use proper caulk to feather and blend to the Ensolite. Then paint. Otherwise rip the silicone out somehow. No matter what method you use, there will need to be some caulk use so you can blend whatever is done to the Ensolite.
boler, vin
removing caulk from ensolite seams laurieh Problem Solving | Owners Helping Owners 3 09-07-2015 08:47 AM
boler interior seams on the insulite Kenny Strong Problem Solving | Owners Helping Owners 15 05-17-2013 10:54 AM
Sealing seams in Boler interior crazeeakerz Modifications, Alterations and Updates 5 01-10-2012 11:18 AM
Removing silicone! Crystal, Huscroft Care and Feeding of Molded Fiberglass Trailers 30 07-28-2009 10:38 AM
removing old silicone from trim Roger Hunckler Problem Solving | Owners Helping Owners 6 10-24-2007 09:38 PM
