Scamp 13 closet opening - Fiberglass RV
Old 11-24-2020, 02:56 PM   #1
TN
Lightbulb Scamp 13 closet opening
Hi there!
We just bought the Ikea Trofast series storage after seeing someone else on this forum successfully install it in their 13' closet. We knew we would have to do some improvising with the overall height, but the width is literally 1/4" too wide for the drawers to easily pull in and out of the closet opening.
Has anyone successfully widened their closet opening? How might one go about doing that? I assume it's as "easy" as removing the lining and shaving down the sides, but what's the easiest way to do this as we are only needing to remove about 1/4"?
Attaching some photos for reference! Thanks so much in advance!
kaylaenglish is offline   Reply With Quote
Old 11-25-2020, 11:18 AM   #2
Trailer: 2016 -13' Scamp
Massachusetts
I would mask off the area to the exact size you require and then use a router to enlarge the opening. You might have to shop around to get a bit that can be used on fiberglass.
herons is offline   Reply With Quote
Old 11-25-2020, 12:57 PM   #3
Trailer: Scamp 13
Massachusetts
Do the drawers slide in and out with the cabinet edge trim removed? Cut that area out of the trim and glue the trim in place so it doesn't move.
Or, just take the difference that you need off the drawers. 3/16 off each side of the drawer should be enough.
Lockman is offline   Reply With Quote
Old 11-25-2020, 01:33 PM   #4
Trailer: Escape 19 2018
Ohio
The opening for the Trofast has to be cut big enough to slide the unit in. A thin cutoff wheel (1/16") on a die grinder or angle head grinder will also work. It is a very messy job, remember fiberglass dust is dangerous. I add a taller Trofast to a Scamp 16 closet. After it was inserted I secured it in the closet with screws from the outside. Spacers had to be installed between the Trofast and the inside of the closet to line it up in the opening. I then trimmed the opening with scribed furring strips to fill the front of the closet fiberglass. Also I built new double doors, so that when opened the doors would not block the aisle.
Doug King is offline   Reply With Quote
Where do you get Scamp front opening window? amy in maine Care and Feeding of Molded Fiberglass Trailers 22 04-20-2024 02:03 PM
Fitting 13' Scamp into garage with 7' opening mkrueger Problem Solving | Owners Helping Owners 4 11-02-2021 09:38 PM
roof fan for Scamp 13 oversize vent opening JPBrown Problem Solving | Owners Helping Owners 7 11-12-2019 10:28 AM
Scamp 13 Door Keeps Opening While Towing barryra Problem Solving | Owners Helping Owners 18 07-30-2019 08:58 PM
Enlarging closet door opening. Wallo Modifications, Alterations and Updates 21 06-08-2014 10:06 AM
