All -
Thanks for the wisdom and input, sounds like it might not be the best of ideas to go with something like line-x, especially thinking through Bill's post about if I ever wanted to take it off.
Having picked up the 4500 and after cleaning and spending a few nights in it to get a sense of things I have a big list of things to do before I even tackle the outside.
Joe - I will most likely be contacting you as i have a few issues to tackle and will want to see about some replacement parts.
The issues / things I will likely need are:
1. Inside door handle is broken half off, will need to find a replacement for that.
2. The right side of the back rear window has been completely "gutted" to put a small window AC unit. I'd like to take that out, but all of the aluminum channels are gone and just bordered up and sealed. No idea how to find a replacement window or fix the old one.
3. I'd like to convert the front bench/bunk into a dinette instead, I've seen a thread where someone just cut the existing bench down and used a wood frame. Wondering if Joe or someone sells the two complete
fiberglass dinette seats where I can just remove the entire thing and install those instead.
Alot to do for sure on this, welcome any wisdom from the group as I get started.
