Setting up a System - Page 3 - Fiberglass RV
Old 07-23-2020, 08:08 AM   #41
Markz's Avatar
It would take me 3.15 years to draw down the batteries at .01 amps. However, I will be looking out for parasitic loads and have a likely suspects I'll be looking at ie: radio, speaker, system, converter, furnace...
Great question: How does one discover and measure parasitic loads in their system?
I will be using switches to isolate most loads; maybe just switching everything off one-by-one and watch if the meter drops, then repeat with a new switch?
Old 07-23-2020, 09:01 AM   #42
You need a sensitive current meter and place it in the line from the battery. A digital multimeter on Amps would suffice.
Measure the current flow and disconnect things to find out what is drawing the current.
You can also place the meter across the shunt and measure on the millivolt range and then do the same thing. the higher the voltage the more current.
The shunt is usually in the negative ground line of the battery(s). It draws no current itself, just a very very small voltage drop proportional to the current going through it.
If the shunt has been bypassed with any other grounds (to the battery) it will not read them.
Old 07-23-2020, 10:45 AM   #43
Markz's Avatar
Yes, I could use the shunt. So long as I know the draw from the shunt's meter, everything else would be parasitic loads that I could isolate through the switches.
I have yet to wire in the shunt/meter.
Old 07-27-2020, 05:25 PM   #44
Markz's Avatar
Made some progress on the cooling fan and panel install today. Click image for larger version
ID:	136326Click image for larger version
Old 07-27-2020, 07:20 PM   #45
Markz's Avatar
Got the lithium battery heating system installed too. Just need to wire in the thermostats now. Click image for larger version
Old 07-28-2020, 02:52 PM   #46
Markz's Avatar
It all fits!!! The tolerances are a bit tighter/closer than I imagined, but so far so good. Click image for larger version
Old 07-28-2020, 04:00 PM   #47
Everywhere
Nice packaging there. The breakers up-top are nicely done as well.
Old 07-28-2020, 04:22 PM   #48
Markz's Avatar
Thank you very much.
Old 07-28-2020, 09:01 PM   #49
Markz's Avatar
Control panel with thermostats to be wired in. Click image for larger version
Old 08-06-2020, 10:01 AM   #50
Markz's Avatar
Hope all is well and everyone is safe.
Old 08-06-2020, 10:19 AM   #51
Markz's Avatar
Doing a bit of labeling.
Originally Posted by Markz View Post
Hope all is well these days.
Just need to install a Flux Capacitor now. Click image for larger version
Old 08-06-2020, 10:33 AM   #52
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
I have a 30 megaquatloom flux capacitor for sale if you are interested!
Looks like you are having more fun the law allows!
Your heirs will inherit money and stuff when you are gone. You can only save or spend money, but you can do things with stuff, so they are going to inherit stuff!
CarlD is offline   Reply With Quote
Old 08-06-2020, 11:29 AM   #53
Markz's Avatar
I'll trade you my Arc Reactor for your Flux Capacitor.
These campers do take you "BACK TO THE..." simpler life.
Old 08-10-2020, 07:43 AM   #54
Markz's Avatar
Got the Flux Capacitor installed today. Click image for larger version
Old 08-10-2020, 10:45 AM   #55
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Old 08-17-2020, 11:53 AM   #56
Markz's Avatar
Finally settled on the wiring chart that works.
Old 08-17-2020, 02:38 PM   #57
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
That looks better. I think you'll have plenty of power.
Old 08-18-2020, 05:16 PM   #58
Markz's Avatar
Got to warn about all that extra power :-)Click image for larger version
Old 08-18-2020, 06:00 PM   #59
dleverton's Avatar
Got the Flux Capacitor installed today. Attachment 136675
Do you have it connected to the turbo-encabulator?
Doug
dleverton is offline   Reply With Quote
Old 08-18-2020, 07:45 PM   #60
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
for those that don't know.
boler, box, cargo, controller, ctek, inverter, lithium, propane, solar, tongue box, wiring
Setting Up city Water Bonnie Problem Solving | Owners Helping Owners 4 11-14-2007 03:45 AM
Fix your board setting for time Donna D. General Chat 1 11-05-2007 08:51 AM
setting up sun juice ronsmith100 Electrical | Charging, Systems, Solar and Generators 2 09-19-2007 11:56 AM
Setting for Fridge Alan P. Problem Solving | Owners Helping Owners 5 08-13-2007 04:19 AM
Setting tension on sway control Chris Z Problem Solving | Owners Helping Owners 3 04-13-2006 10:29 PM
