1974 Boler 13 New to Me - Fiberglass RV
Old 09-05-2020, 10:24 AM   #1
Trailer: 1975 Boler 1300
Hello to the group
I am the new owner of a 1974 Boler 13 and would like some ideas/suggestions on my trailer. I live in Ontario. Canada
My Boler has been painted at one time probably using a roller and brush, underneath the paint is the outline of a wide stripe and possibly one or two small stripes, I am not able to remove any paint to see the underlying colour, the stripes may have been removed but the backing was left behind.
Has anyone seen a Boler 13 with stripes and would you have pictures, I want to repaint the Boler some time and would be interested in returning it to original paint scheme. It appears to be white top over a yellow bottom. The stripes were just above the waist line.
Secondly, I am considering mounting a flexible solar panel to the roof, I see in the comments on various panels that heat and de-lamination are a problem, what are your experiences and how might I space the panel off the roof without drilling holes in the fiberglass, I would prefer something like 3m tape if possible.
Thank You for any suggestions
Kevin
Kevin_Lemon is offline   Reply With Quote
Old 09-06-2020, 10:54 AM   #2
daveandbonscott's Avatar
Name: Dave and Bonnie
here's a common colour stripe on a 77' 17' Boler
daveandbonscott is offline   Reply With Quote
Old 09-06-2020, 11:27 AM   #3
Trailer: 1978 Boler
Almonte, Ontario
Roof mounted solar panels generate an enormous amount of discussion on this site with opinions ranging from tape to bolting on. Personally, if I was mounting my solar panel, I would go rigid panel and fibreglass the mounts to the roof for security, airflow and maintenance (tape is good but the tug on the tape weakens it over time if you are doing any service or repairs).
Nicolas is offline   Reply With Quote
Old 09-06-2020, 05:30 PM   #4
Thank you for the pictures.
The stripes on my Boler are both above the belly band, the lowest one is about 2 1/2" wide and the second about 1 1/2" wide and about an inch above the first. I haven't been able to discover their colors yet.
Old 09-06-2020, 05:34 PM   #5
Hi Niicolas, thank you for the answer, I would really not want to put holes in the roof of my trailer, to me its the same as putting holes in the bottom of my boat .
I also don't want to mount a flat panel on the roof because I don't want to drastically change the outline of the trailer. I may just stay with my fixed panel on an external mount.
Old 09-07-2020, 11:57 AM   #6
Trailer: 1978 Boler
Almonte, Ontario
One of the wonders of fibreglass is its ability to be repaired and bonded together. My suggestion comes from the Gougeon Brothers’ Fibreglass Repair manuals. They recommend determining where you want your mounts to go; rough the area with sandpaper; mix a fibreglass bonding paste; apply to the roughed area; stick the mounting into the paste; allow to dry; finish the base of the mount with more paste and then with fairing compound. As you can see, there are no holes and therefore no risk of making the roof like the bottom of your boat.
However, like your decision to not change the outline of your trailer, I too went with a flat panel which is external and well chained to my Boler since apart from the aesthetics, I am limited height-wise by a garage door.
boler
New owner of 1974 boler ReneeN Hi, I am.... 9 05-20-2020 08:38 PM
From Vancouver, with our 'new' 1974 Boler rdyn Hi, I am.... 4 10-23-2017 09:27 AM
Replacing 1974 boler hinges with new scamp hinges ArneB Modifications, Alterations and Updates 2 08-10-2015 12:39 PM
New 1974 boler owner :) ShelleyP Hi, I am.... 0 07-30-2014 03:11 PM
1974 Boler : THE TANK - new flooring Jayson Wall Modifications, Alterations and Updates 10 07-05-2007 08:16 AM
