How far or how long to drive to recharge a Casita 16' battery? - Page 3 - Fiberglass RV
Old 09-24-2020, 08:31 AM   #41
Trailer: 2005 casita sd
Originally Posted by Radar1 View Post
Since you mentioned running the 12 volt fridge on your trip while driving, I suspect that is a major culprit as the fridge usually consumes more power than the charging system can supply.
Was your 7 pin connector factory installed and hooked up so that it actually supplies 12 volts on the charging wire? Have you confirmed that you are actually getting 12 volts on the charging circuit as you drive? A simple test would be to plug a volt reader into a DC outlet in your camper, check the voltage while the tow vehicle is not running, and then turn the tow vehicle on and see if the voltage goes up (it should) or stays the same.
When we got our Casita, we checked the TV and found that the wire that goes from the TV battery to our pig tail wasn't connected so we had to manually hook it up (after reading on line how to do it).
garycarolyn is offline   Reply With Quote
Old 09-24-2020, 11:04 AM   #42
Trailer: 2018 Casita Spirit Deiuxe
Massachusetts
Turned out the wiring in the camper wasn't connecting the car to the battery. The repair guy who figured that out then fixed it and it has worked great ever since.
Lisle is offline   Reply With Quote
Old 09-24-2020, 02:54 PM   #43
NW Wisconsin
To limit battery drain , on nights where the outside temps are above freezing, we turn the furnace on right before going to bed to warm up the trailer , then shut the furnace off until morning, then start it up again to take the chill off
We have gone 3 to 4 days on a single 27F battery without recharging
We do carry a heavy wool blanket with us when camping in the Spring & Fall
battery, casita
Sorry - a battery recharge question Infogypsy Electrical | Charging, Systems, Solar and Generators 12 09-11-2013 10:58 AM
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
How far is too far.... Time K General Chat 11 04-06-2009 05:44 PM
How far is too far .... Steve Dunkel General Chat 21 04-05-2009 01:53 PM
AC Recharge Benita Problem Solving | Owners Helping Owners 12 07-07-2006 03:03 PM
