Portable solar panel config for Trillium 1300 - Fiberglass RV
Old 09-19-2020, 06:34 PM   #1
Mark in Comox's Avatar
Trailer: Trillium 1300
Someone asked me to post setup on our Trillium 1300 for solar charging the deep cycle batteries... so here it goes..
Two stacked batteries wired in sequence and connected to an AC marine charger in the tongue box that run the fridge and lights.
Also directly cabled to the batteries is an 8.5 amp solar charge controller shown here:
Wires come out back of box and I have a long extension cable that connects and let’s me move panel around:
ID:	137495Click image for larger version
The panel itself is 100 watts with same plug connectors from Canadian tire and has a simple plywood stand to hold it up:
Works great and panel and stand just slide back into box for travel and cables store in the tongue box....
Mark in Comox is offline   Reply With Quote
solar, solar panel, trillium
Portable solar panel(s) plugged into 7-pin connector??? OCJohn Electrical | Charging, Systems, Solar and Generators 29 05-22-2019 12:26 PM
SolPad: Portable battery, inverter, solar panel combined EllPea in CA Electrical | Charging, Systems, Solar and Generators 8 02-18-2017 07:22 AM
100 Watt Portable Solar Panel Bruce H General Chat 10 10-08-2013 09:47 AM
Portable Solar panel. What are you using to hold it down? Kevin K Electrical | Charging, Systems, Solar and Generators 5 05-23-2013 11:36 AM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
