DC to DC Charger with MPPT controller + lithium iron phosphate batteries - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Electrical | Charging, Systems, Solar and Generators
Old 11-17-2020, 07:08 PM   #1
Trailer: Escape
Hello all, I have a 2013 17ft. escape trailer. I am putting in 2 X12V 80Ah lithium phosphate batteries in parallel. I am disconnecting the battery connections to the WFCO 8900 distribution center. I am installing a 20 Amp. Renogy DC-DC charger. I have a 95W Go Power solar panel on the roof that I am pairing with a
20Amp Renogy MPPT controller. So my question is: will there be conflict between the DC-DC charger and the solar input with both going to the batteries?? Mostly I wonder if the DC-DC charger might damage the controller.
Any feedback would be appreciated as I am trying to figure this out as best I can
IanHall is offline   Reply With Quote
Old 11-17-2020, 08:08 PM   #2
Red face
I was trying to figure out the DC to DC charger issue with 200W of solar panels and not wanting to upgrade my tow vehicle wiring. I am using a 100A lithium battery. The CTEK 250SE DC to DC charger was recommended and several others agreed. It is DC to DC charger combined with a MPPT controller. I have not installed it yet in my trailer.
Eddie
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-17-2020, 08:25 PM   #3
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
I wouldn't anticipate any issues. I have 200 watts of PV, a 20 amp Renogy MPPT and a Victron 9 amp DC-DC charger between the TV and trailer, and it works fine. Set the MPPT and DC-DC chargers to the same voltage. I can provide some theory explaining this if you like. ALSO, run a dedicated fuse and wire from the TV battery to the where the trailer connector is, a dedicated return wire is also advisable. I am not sure of the maximum current you can put thru the 7 pin connector so you need to figure that out. And you will have to make sure you have wire that can handle the maximum current in your trailer, including the return wire.
The TV wiring and trailer wiring from the connector to the DC-DC will have to be able to handle in greater than 20 amps of current. This is due to the different voltages, efficiencies, and line losses. Volts x amps = power. If your LFP battery is at 14 volts and drawing 20 amps the DC-DC converter will need to supply 14x20= 280 watts of power. The TV will have to supply that, PLUS the efficiency losses in the DC-DC converter, PLUS the line loss in the TV and trailer wiring to the DC-DC converter. Assuming 85% efficiency of the DC-DC converter, I could easily see your TV having to supply 280/.85=330 watts of power at the input of the DC-DC converter. If you assume 50 feet of 10 awg wire you will have approximately .05 ohms of resistance. Which means your TV will have to supply an additional .05 x 27 amps squared = 36 watts of power. It adds up to approximately 330 + 36 or 366 watts. If your TV alternator puts out 13.8 volts it will have to supply 366 watts/12.5 volts (at the DC-DC converter) = 29 amps. The current draw from the TV is actually a differential function and I am not going to go there so I estimated the current at 27 amps. I made some assumptions with these calculations which you should verify based on your design and converter efficiencies.
My 9 amp DC-DC converter draws about 13 amps when operating.
Hope this is not to confusing.
Your heirs will inherit money and stuff when you are gone. You can only save or spend money, but you can do things with stuff, so they are going to inherit stuff!
CarlD is offline   Reply With Quote
Old 11-17-2020, 09:03 PM   #4
Trailer: Escape
The Wiring
I am running 10AWG X2 silicone from the 4runner battery to the DC-DC charger located in the front area of my trailer under the bed. Then running 10AWG X2 wire from the DC-DC charger back to the batteries. I will put a 40 amp fuse at the 4runner battery and at the LiFePO4 batteries. Putting connector for this where my trailer electrical hookup, at the tongue, is located. I realize in my original post that any potential conflict between DC-DC charger and MPPT controller is kind of an isolated issue, in that the DC-DC charger is only working as I drive. The reason for disconnecting the WFCO center from the batteries is that it will not recognize the lithium... and may mess with them.
Old 11-18-2020, 02:25 AM   #5
ThomasC's Avatar
Trailer: BigFoot 25B25RT
Massachusetts
I have a Renogy DCC50S 12V 50A DC-DC On-Board Battery Charger with MPPT. It is all one unit and the instructions specified 4 awg wire. I have the truck wired but I am in the process with the camper.
ThomasC is offline   Reply With Quote
Old 11-18-2020, 11:55 AM   #6
Trailer: Northern Lite
I have the Renogy 20A DC-DC charger. It draws 30 amps at full output (20A output). That amount of current found a weak spot in my stock 10 ga wiring - I experienced a failure in the umbilical cord (when I took it apart I found a very sloppy connection in the female plug, causing a bit of a melt). Anyway, the charger has a half-current setting which I enabled, (after repairing the plug) so it now draws 12 - 13 amps and outputs 10 amps.
Rustofer is offline   Reply With Quote
Old 11-18-2020, 12:14 PM   #7
Trailer: Escape
DC-DC Charger and Wiring
Thanks for all the input... it actually looks like I can't disconnect the WFCO Distribution Center from charging the battery... as I would then have no 12V source to power it . We never stay in campgrounds so don't have a 110V plugin on our trips.
Old 11-18-2020, 12:21 PM   #8
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
An Anderson plug mounted on the rear bumper is an excellent way to easily connect a dedicated 50 amp source to the trailer. This one uses #6 wire and I have a 50 amp circuit breaker next to the tow battery.
To hook up, I plug in the conventional seven pin, and the separate Anderson plug that runs alongside it. In my system, the Anderson is always live on the truck side. When stopping for the night, I don't bother to unplug it. In sunny weather, the solar peaks out at just over 250 watts to the trailer batteries, and would, if needed send some to the truck as well. I have four 100 AH AGM batteries in the trailer. The truck has an alternator that brings everything up to 14 volts, and then drops to 13 volts as a float charge. The solar controller is an MPPT and ties the panels directly to the batteries at the same point as the Anderson wires. This system is simple, has no conflict with different power sources, sends a powerful charge to the house batteries from the truck, and the Anderson plug on the trailer can be used a a power source to run a 12volt compressor, electric/hydraulic jack (for tire changing), or as a point to plug in a suitcase solar system. It can also be used to charge the truck if I get a dead battery. In my case, there is a junction box on the tongue where the #6 house battery charging wires connect to the Anderson pigtail that plugs into the truck. That junction box is where I get power for the emergency breakaway switch. It can also be used as a source for an electric tongue jack, if desired, but I prefer a manual jack.
Old 11-18-2020, 12:31 PM   #9
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Here is another way to look at it. If you look at the specifications, the Renogy 20-20 charger will operate down to 8 volts on the input. Assuming 14 volts on the output at 20 amps, the charger will output 20 x 14 or 280 watts. Lets call the efficiency 95% this time. The input power will be 280/.95 or 295 watts. If the voltage drop in the wiring from the TV is such that the voltage at the charger is 8 volts, the charger will draw 295/8 = 37 amps! You have to design for that value. As mentioned above, one bad connection and you can have melt down. The smaller the wire the larger the current. Also remember that copper has a positive temperature coefficient, which means the hotter it gets the higher the resistance. In this situation that means it will have greater voltage drop causing the charger to draw more current which will only heat the wire more. Positive feedback as the say! This may not seem intuitive but that's the way current sources work.
Old 11-18-2020, 12:40 PM   #10
Trailer: Escape
WOW, what great feedback. Having a 17ft. trailer being pulled by a 4runner sport edition my wire distances are within the specs. put out by Renogy. I am using an anderson type plug at the tongue. My circuit breakers are actually
30amps.; not 40amps. as previously stated. I feel a lot better about putting this system together after having more experienced input. Thanks.
Old 11-18-2020, 01:03 PM   #11
Raspy's Avatar
Trailer: Roamer 1
Carl,
That is why #6 wire from the TV is a good idea. And why the 50 amp Anderson plug style is so good.
I have never tripped the 50 amp breaker next to the truck battery, but I have measured 24 amps feeding the trailer when the trailer batteries were nearly at full charge. So, I'm certain it is in the range of 24-50 amps being fed back to the trailer, depending on the state of charge. After stopping for the night somewhere, and we almost never have hookups, or even use them if available, I'll see the truck output at 14 volts for an hour or so, and then it drops to 13 for float. There is no tenths reading, so I don't know the exact voltage coming from the truck.
The MPPT solar takes the final battery voltage to 14.5 during its absorption phase. So the truck mainly gives the bulk charge, and some absorption. In poor weather, or shade, and after a couple of days of weak solar charging, I can idle the truck and give the trailer a bulk charge, for a half hour or so, of nearly 50 amps.
This setup is so simple and maintenance free, that I hardly think about it now. I just look at the battery voltage on the monitor, once in a while to see how it's doing. Every morning, I make coffee in the electric coffee maker, sometimes two pots. We charge the electronics, run the heater as needed, watch a movie or two, use all the lighting we want, and run the microwave to re-heat things. A very comfortable amount of power with almost no thought.
Old 11-21-2020, 12:49 PM   #12
Trailer: aliner
No DC-DC as primary LFP battery charging for me
DC-DC AS PRIMARY LFP BATTERY CHARGING
Early warnings when charging LFP batteries included NOT to continually charge to 100% or lifespan would be reduced. Confirming that guidance:
* Early Lithium chargers only put out 14.4-14.6vdc. Common user practice was to monitor SOC and disconnect charging when near 100%.
* Recent LFP chargers like WFCO start at 14.6V for 1 hr. to balance battery cells then, when monitored charging current drops, output voltage is reduced to 13.6v. Full description is in the operator manual referenced below.
Most Solar controllers perform the similar Bulk then Absorption charge voltages.
DC-DC CHARGING FROM TowV
TowV battery to my RV battery is about 50'. That's about 100' round trip for most OEM #10 wiring. Per West Marine site referenced below, I can get 10A @12vdc for 100' using #10AWG with 10% drop. That's consistent with my testing using a Victron Orion-Tr 12 12-9 isolated DC/DC converter.
During installs to charge LFP batteries, I:
* Set these to 14.1v output to avoid 100% LFP charging
* Know they'll be charging slowly at <9A only while driving (not full time).
MY TAKE: Avoid using DC-DC converters for primary 100% charging unless they or you can follow Bulk-Absorption charge levels like Solar and WFCO follow. These batteries are too expensive to accidentally cook.
I apologize for being late to comment. I was enjoying 70dF camping and hikes at Inks Lake in Texas hill country in November! I hope this helps.
Mel
https://www.westmarine.com/WestAdvis...e-And-Ampacity
http://wfcoelectronics.com/wp-conten...Ion-Manual.pdf
MelH is offline   Reply With Quote
Old 11-21-2020, 04:12 PM   #13
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Mel, I have a progressive dynamics, which Battleborn sells, in my camper. It is basically a constant current, constant voltage, 14.6 volt, 40 amp power supply. Per Battleborn, they say the equalization happens when the battery voltage is above about 14.2 volts. The BMS shuts off the battery when it is fully charged. I am not sure what LFP battery you have and maybe it reacts differently, but I can't imagine Battleborn selling a charger that is not compatible with their batteries which have a 10 year warranty.
Old 11-21-2020, 05:59 PM   #14
Trailer: aliner
Vendors can only sell the best available equipment at that time. Many of us bought those because those were the best available.
But instead of constant voltage, the current Progressive Dynamics Converters and most other manufacturers now offer or only sell variable voltage strategies similar to the WFCO I'd mentioned.
Many LFP vendors have long offered 10 year warranties regardless of the charger.
My thought is with the improved charge strategies, converter manufacturers now help us maximize our battery operation time and improve the number of measured cycles (that some batteries count and report).
I think constant voltage will work but it is not the latest battery maximizing technology. I believe that was worth mentioning when someone is considering a DC-DC converter that only put out a constant voltage.
Mel
Old 11-25-2020, 02:10 PM   #15
Trailer: None
I use a Victron 18A DC-DC converter to charge from the stock converter and to charge from the TV via the 7pin. I wired a relay so that the DC-DC converter is normally connected to the stock converter, and when it senses 12v on the tow harness the relay energizes and disconnects the stock converter and connects to the TV. (It’s a SPDT relay).
This did require a little bit of rewiring. The existing tow charge wire on the trailer side now only serves to supply 12v to the emergency trailer brake. I ran a new 8ga 12v from the tow harness inside the trailer back to the relay. Also disconnected the converter from the 12v DC distribution panel, and it now runs back to the relay. Added a high amperage fuse block to fuse the DC-DC charger, an inverter, PV charger, and then the existing trailer DC distribution panel.
Sounds confusing without a picture as I re-read this. However on the plus sign, LifePO4 is great and I get a ton more watts/AH in the same form factor and not worrying about drawing below 50% is great.
David_KTN is offline   Reply With Quote
Old 11-25-2020, 07:43 PM   #16
Trailer: Lil Snoozy
MD
I have a setup very similar but not exactly the same as Carl's: Victron 9 amp DC/DC converter, Victron MPPT 100/30 solar charge controller, etc. charging two 100 Ah Battleborn Batteries. I think the 4Runner stock wiring to the 7-pin connector is 12 ga and the Snoozy wiring to the trailer batteries is 12 ga. I estimate the 4Runner wiring at 15 feet and the Snoozy wiring at 20 feet. I doubled the trailer wiring to two 12 ga. The DC/DC converter is set to 14.2 volts and charges the batteries via a 12 ga wire and 10 amp fuse. The Victron MPPT solar controller is set to 14.6 volts absorption and 13.6 float per BattleBorn, and charges via a 10 ga wire and 30 amp fuse.
I have been running it with these settings for a couple of years and observe the DC/DC converter charging at or near 9 amps pretty regularly after boondocking. I don't think that I would be comfortable charging more from the TV with the stock wiring.
I did run a 10 ga wire from the TV battery to the rear of the 4Runner and it is pretty easy to do, but that runs a separate system of roof solar panel, 9 amp DC/DC converter, MPPT solar charge controller, and 50 Ah BattleBorn battery to keep a fridge running in the back of the 4Runner.
This is all just for your info and perspective. Good luck on your build, I think you will love the LiFePO4s.
Air Doug is offline   Reply With Quote
Old 11-30-2020, 09:13 PM   #17
Trailer: Escape
WFCO 8900 series with 3 stage lead/acid charging profile
So, I am finding all this amazing input a bit over my bald head. So to recap, I have Renogy 20amp DC-DC charger located in the front of my 17 foot trailer.
I used 8awg wire from my 4runner battery to the DC-DC charger; then 10awg wire back to the batteries inside, at the back, of my trailer. I also installed a
Renogy 20amp. MPPT Solar Controller with a 95W panel on the roof, and a 100W panel outside. My trailer is from 2013, so it has the stock WFCO 8900
series Ultra 3 Distribution Centre. There is a battery shut off switch as the positive wire comes out of the distribution centre. This WFCO has 3 stage charging for lead/acid batteries. My worry is that the WFCO charging system might mess with my LiFePo4 batteries (2X 80 Ah. Scremower) or the other
Renogy components. I could use the switch to disconnect the WFCO from the batteries when I am driving or plugged into 110V (when hardly ever happens).
Should I be worried about "progressive" charging?? Is the WFCO centre going to cause me problems?? I am just now installing all this stuff. Any help would be much appreciated. Thanks.
Old 12-01-2020, 07:57 AM   #18
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
1. My biggest concern is the 20-20 amp charger melting wires or connections. Make sure you keep an eye on the input current. I would recommend, as mentioned previously, running it at half current.
2. Your WFCO will charge the LFP battery but not ideally. The voltage is too low and it will charge it slower than a LFP charger. I would recommend upgrading at some point.
3. I am not sure how the BMS in your LFP batteries work, but I do know that Battleborn's BMS equalizes (balances) their batteries at around 14.2-14.4 volts, so you must reach that voltage on occasion. If your WFCO has an equalize mode it will take care of that. Your other charge devices should be programmed to reach this voltage which can satisfy this requirement.
4. Regarding compatibility between your various chargers, I don't anticipate any issues. I have the same solar controller as you and a 9 amp DC-DC charger, both connected all the time, and have no issues.
Let's look at a couple scenarios.
4.1 The battery is at a low charge state. Assuming all the chargers are operating, they will all supply current to the battery.
4.2 The battery is nearing full charge. Assuming all chargers are operating, The bus voltage may be above the setpoint of one or more of the chargers. These chargers will stop supplying current and the one with the highest voltage setpoint will continue to charge the battery. No current will flow from the operating charger into the other chargers.
4.3 If the battery just reached full charge the voltage will be approximately 14 volts. If you unplug the trailer from shore power, turn off your TV and the sun goes down, you have nothing charging the battery. The battery will not discharge back into the chargers.
4.4 You don't have to be concerned with one charger operating while others are turned off. This happens all the time with my system.
In a nutshell, connect everything together, set your charger voltages and currents and have fun.
Old 12-01-2020, 12:52 PM   #19
Trailer: Escape
Thank you for the very detailed and thoughtful reply; particularily as it applies to my set up. It does help to unmuddy the waters. All the best.
Old 12-01-2020, 03:32 PM   #20
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Ian, One other thing to consider. I looked at the Scremower battery on Amazon. The BMS does not seem to have temperature protection. LFP batteries do not like to be charged if it is below freezing as it will destroy it. I would install the batteries inside the TT so they stay warm while being used. Unless you are storing your trailer in an environmentally controlled enclosure, disconnect the battery from all charging sources. It is ok for them to go below freezing for storage and even discharging, but not charging. Depending on your situation, you might want to remove them from the TT and put them in your basement.
escape
For Sale: 125Ah Smart Lithium Iron Phosphate Battery, New in box, free shipping MelH NEW Fiberglass RV Classifieds | Buy, Sell, Trade 1 05-08-2020 07:14 PM
For Sale: Smart 125Ah Lithium Iron Phosphate battery, New in box. MelH NEW Fiberglass RV Classifieds | Buy, Sell, Trade 0 02-01-2020 11:43 AM
How Do I Size MPPT Charge Controller? Huck Electrical | Charging, Systems, Solar and Generators 9 07-17-2018 03:18 PM
Lodge Cast Iron Dutch Oven, Griswold Waffle iron & more Gigi Classified Archives 2 06-23-2008 05:44 PM
