outside light - Fiberglass RV
Old 04-03-2020, 04:21 PM   #1
Trailer: Burro 13’
outside light
I need to replace the bulb on the light outside by Burro door. It says GE 1995 but no wattage. Also if you know where I can buy one. Thanks
LuckyPenny is offline   Reply With Quote
Old 04-03-2020, 04:43 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
I'd take it to an auto parts store and see if they have a 12v one that will fit. Your number GE 1995 doesn't seem to exist online.
Charlie Y
tractors1 is online now   Reply With Quote
Old 04-03-2020, 04:48 PM   #3
Trailer: Burro 13’
Thanks for the suggestion. I just ordered a bulb online and will see if that works, I'll post the source.
Old 04-03-2020, 06:16 PM   #4
AC0GV's Avatar
Wisconsin
Lamp picture
If you post a picture here, I'll bet we can figure out what IT is as well as an LED replacement.
AC0GV is offline   Reply With Quote
Old 04-03-2020, 08:27 PM   #5
ThomasC's Avatar
Trailer: BigFoot 25B25RT
Massachusetts
Could it be an 1895 bulb? Does the bulb push in or is it a bayonet type that goes in with a quarter turn twist?
Either way you should get a led equivalent.
ThomasC is offline   Reply With Quote
Old 04-05-2020, 10:55 PM   #6
CharlesinGA's Avatar
Georgia
Replacing the bulb in the fixture without knowing if it is the correct bulb for the fixture could be a minor disaster in the making. Many of the outside fixtures (actually most RV light fixtures) have stamped or molded into them the correct bulb number. Often people install an incorrect replacement bulb and many times that bulb is a much higher wattage and makes more heat. Look closely at the inside of the fixture, look for writing or etching, stamping or imprinting that might tell you the bulb number. Then you will have the correct lamp.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
burro, light
Outside light Dalknob Problem Solving | Owners Helping Owners 0 08-13-2015 03:39 PM
Outside light question Steve_74 Problem Solving | Owners Helping Owners 9 10-14-2014 03:12 PM
Anyone Have Outside String Light Ideas? barryra General Chat 25 07-15-2012 08:00 PM
Replacing Outside light on Boler Ann B Modifications, Alterations and Updates 20 10-07-2006 02:14 PM
outside light switch won't move Karalyn Problem Solving | Owners Helping Owners 13 05-31-2006 09:14 AM
