Recommendations for Replacing the Axle - Fiberglass RV
Old 04-27-2022, 06:15 AM   #1
MI
NOTE: This is a reply to my post here:https://www.fiberglassrv.com/forums/...amp-98439.html
Originally Posted by Eddie Longest View Post
I've played the bring home game many times with project trailers. It's a big relief when you get it parked in your driveway. One note on the tires and wheels. Your trailer has 13" tires with 4x4 lug pattern wheels. In all likelihood you will be replacing the axle. The most popular lug pattern hubs are 5x4.5, and most people go with 14" tires. An axle with 4x4 lugs has to be special ordered and there are very few choices in 4x4 wheels. I have run out and bought new 13" tires and wheels and found out I should have upgraded to 5x4.5 wheel for a new axle. Note: If you get Scamp to do your axle swap, they use 5x4.5 lug spindles. Eddie
I was thinking the same way. I noticed the old axle is welded on. I can cut it off and weld a new one on. I briefly reviewed the Dexter website.
What is the consensus on which axle to buy? I would like it to ride higher; should I have the axle horizontal or down (it is currently up)? How do I center it in the wheel well; just eyeball it? Are they videos or posts you could recommend?
If I were as close to the Scamp factory as you, I would get them to do the axle swap. Make an appointment, show up and in about 2-3 hours you are back on the road with your new axle. Scamp could also change out your coupler.
Eddie
I am 13 hours away from the Scamp factory so I will have to do this locally.
Frank R is offline   Reply With Quote
Old 04-27-2022, 07:24 AM   #2
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
I had my old leading-arm Dexter cut off and a proper trailing-arm Flexiride from Canadian Axle welded on.
I also had e 3" or (4"?) rectangular box welded on the bottom of the frame to make the trailer ride higher with 12-degree down Flexiride angle. They are adjustable so you can change the angle.
There were NO Dexters available for at least a year from Scamp or any other distributor in the USA I called, but Canadian Axle could make me a Flexiride in 10 days.
So now I've got a 5-bolt pattern hub and electric brakes and it's a brand-new (1977) Scamp 13' (I also had the coupler cut off and a 2" one welded on.)
AlanKilian is offline   Reply With Quote
Old 04-27-2022, 08:00 AM   #3
MI
Thanks for the info. I will have to look into Flexride.
To determine what size riser block I need, would you measure the block for me?
I have 1977 also; so this helps a lot.
Old 04-27-2022, 11:09 AM   #4
Massachusetts
My riser is 3"
It does make the step up into the camper high, so we use a plastic step stool outside the door to make it easier to get in and out.
If I were to do it again, I would not add the riser. I don't need the extra 3" of camper height. (It doesn't increase the axle clearance.)
Since I have a Flexiride, I can try adjusting the arms to bring it down and I might actually try that someday.
Old 04-27-2022, 01:40 PM   #5
MI
Thank you.
Old 05-02-2022, 07:39 PM   #6
MI
After reading a few posts on the forum, it seems that a Flexiride axle requires that riser block because it has to mount further up on the frame (under the dance floor) because it is a trailing arm.
It seems like it would be easier to just order the axle from Scamp. The prices are very close.
Old 05-03-2022, 06:34 AM   #7
Massachusetts
That's an important point!
Scamp axles are now trailing-arm, so it would be good to check with the factory if you have an old Scamp and want to use a new axle from Scamp to make SURE you get the one you need. Especially if you have electric brakes. They only work going one way.
I turned my leading-arm Dexter into a trailing-arm Flexiride and it tows beautifully. Although it towed just fine before, so for me it didn't make much change in towing. (Other than that I now have suspension and can put more than 20 PSI in the tires without initiating bouncing-ball-mode.)
If you want a lot of reading, here's a thread from ten years ago.
https://www.fiberglassrv.com/forums/...ing-60297.html
I'm sure there are many more including mine. I went through the analysts-paralysis also when deciding.
Old 05-04-2022, 11:59 AM   #8
Trailer: Amerigo
Wisconsin
There is normally a pin directly under the axle coming thru the springs. On my trailer I had a drop axle I put a straight axle in and it just right height now.
bigangelman is offline   Reply With Quote
Old 05-04-2022, 12:03 PM   #9
MI
Do you have leaf springs or a torsion bar axle?
Old 05-04-2022, 01:24 PM   #10
Trailer: 1979 Layton 22 ft / 2004 Ram-Cummins 2500 2wd
I've only seen 'Drop Axle' referring to 'Leaf spring' and the reference to the 'Center bolt' makes me sure that's what he's referring to.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
Old 05-04-2022, 01:44 PM   #11
Thumbs up A lose the Axle Alternative
If you plan unimproved road operations, you might consider a suspension without the axle which can ground out on obstructions. Texas Customz is working on one.
Stephen_Albers is offline   Reply With Quote
axle, eco
Replacing Boler Roof Vent - looking for recommendations Maraysha in BC Problem Solving | Owners Helping Owners 18 01-21-2021 06:51 AM
Replacing Axle JohnWalker Towing, Hitching, Axles and Running Gear 8 04-26-2006 04:02 AM
Replacing 13ft Scamp axle Legacy Posts General Chat 12 08-21-2003 04:40 PM
Replacing the axle Legacy Posts Modifications, Alterations and Updates 17 01-22-2003 05:54 PM
Replacing Torflex Axle on 13 ft Scamp General Chat 0 01-01-1970 12:00 AM
