GFCI resets for an Escape21 - Fiberglass RV
Old 12-09-2020, 02:58 PM   #1
Trailer: Escape
Where are the GFCI resets on a 2015 Escape 21? A resistance heater I was using tripped the GFCIs at the sink and adjacent to the microwave.
Also, are there any non GFCI protected outlets in the trailer?
AndyF is offline   Reply With Quote
Old 12-09-2020, 03:22 PM   #2
There are two standard GFCI plugs. One is right under the kitchen counter. The other is outside on the passenger side between the axles and the rear of the trailer.
Old 12-09-2020, 04:46 PM   #3
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
And with the newer trailers, at least my 2017 21, the output of the outside GFCI is used to power the under sink receptacle, requiring you to go outside to reset it.
Old 12-09-2020, 09:11 PM   #4
Trailer: 2010 Escape 19
New Jersey
Yes, all the other outlets that didn’t stop working when the GFI tripped.
Seriously though there should be a few outlets that are not GFI protected...at least there are on the trailers I’ve seen.
rubicon327 is offline   Reply With Quote
Old 12-09-2020, 09:57 PM   #5
Trailer: Escape
Well, I’ve tripped two so far, so I must have two GFCIs to reset.
Old 12-09-2020, 10:23 PM   #6
NW Wisconsin
A GFCI is not an overcurrent device , it is designed to protect human life not equipment.
Our escape 21 has an exterior GFCI receptacle that also provides GFCI protection for the kitchen counter receptacle
If my memory is correct your Escape has 2 - 15 amp 120 V receptacle circuits
If you lost power to all the 120 VAC receptacles in your trailer ,I doubt your problem is a tripped GFCI
Old 12-10-2020, 01:50 AM   #7
New Jersey
Thanks Steve. Thinking the same. Also if the OP has the inverter with all outlet option they could have a breaker tripped in the remote mounted sub-panel (typically two 15A breakers) and not in the traditional WFCO power center breaker line up.
escape
For Sale: 2016 Escape Escape21 Classic 5wilson NEW Fiberglass RV Classifieds | Buy, Sell, Trade 4 10-15-2019 08:46 AM
Does anyone have a GFCI outlet at the Kitchen Sink? Jeff T Electrical | Charging, Systems, Solar and Generators 39 03-20-2018 01:34 PM
Need Help with Outside GFCI Recepticle Kevin A Problem Solving | Owners Helping Owners 4 06-09-2009 09:23 PM
Ground Fault Circuit Interrupters-GFCI Pete Dumbleton Problem Solving | Owners Helping Owners 0 04-13-2008 03:43 PM
