Recommendations for Polyester Filler - Fiberglass RV
Old 05-05-2022, 07:53 AM   #1
MI
I need to fix the sagging roof. I haven't committed yet but it looks like I will be grinding off the gel coat and laying down two layers of 12 oz biaxial fiberglass cloth. After that it will be a lot of filling and sanding. I have always worked with epoxy filler and never with polyester filler.
Do you have any recommendations on which brand to use? Bondo? Eastwood? Evercoat? Total Boat?
Any other recommendations?
Frank R is offline   Reply With Quote
Old 05-05-2022, 09:10 AM   #2
MI
https://help.summitracing.com/app/an...hould-i-use%3F
I just found this. Looks like a premium filler is the best type.
Old 05-05-2022, 09:13 AM   #3
Name: Bill & Jeanie
Trailer: Building camper in Ram Promaster van
I would recommend staying with epoxy rather than switching to polyester. I worked with polyester for decades until I switched to epoxy about eight years ago. To my mind virtually all the characteristics of epoxy are superior including generous working time up to 30 minutes, generally better bonding to a variety of surfaces, and ability to completely harden in one day ready for sanding. There is no gummy surface layer that polyester often has until it has dried for a number of days. I use fillers with epoxy to obtain just the right viscosity for the job at hand.
I think if you are used to the advantages of epoxy it will be difficult for you to go back to polyester resin.
wbullivant is offline   Reply With Quote
Old 05-05-2022, 10:08 AM   #4
David Tilston's Avatar
What do you mean, "switching to polyester"? As far as I know, Scamp trailers were made with a polyester resin at the factory.
What you forgot to mention in the characteristics of epoxy is that polyester has trouble sticking to it. So, if you, "switch" to epoxy, you have to stay with it.
Since I always use polyester, I have no idea what epoxy costs. How much is a gallon of epoxy?
I don't consider myself any kind of expert, but I have sanded polyester resin a few hours after laying it down. I have not noticed any gummy surface layer, other than that time when the fibreglass was still wet from washing it. The resin never hardened and I had to sand, (wipe) it off and start again.
Old 05-05-2022, 11:08 AM   #5
MI
Dave, you bring up a good point.
After I have ground the gel coat down to the fiberglass, what should I use to adhere (wet out) the fiberglass cloth I am using to strengthen the roof?
I want this to be strong to avoid sag and I only want to do it once.
Old 05-05-2022, 12:06 PM   #6
Frank, I'm sorry to say that I think you are going about this wrong. Not that I have any personal experience with what you are doing.
As I have said elsewhere. I would use pultruded 1" square fibreglass, running side to side, on top of the roof, where the sag is worst. No need to strip the gel coat anywhere other than where the square tube is glued down. I would bevel the ends at 45° and close them off with fibreglass. I think that if this is done just to the top of the trolly roof, it would not be an eyesore.
Name:	Pultruded 1 inch square tube.JPG
https://www.grainger.ca/en/product/S...-FT/p/WWG4ATN8
Another approach is to use foam sandwich construction. Many boats are made this way. First you glue the foam to your fibreglass, then fibreglass over the foam. This is lighter than multiple layers of fibreglass:
https://www.fibreglast.com/product/g...core-materials
The folks at Trillium/Outback now line the inside of the trailer roof with some non-woven fabric and fibreglass over it. I assume that the fabric does not absorb the resin. Joe Thoen tells me it is quite expensive, but he didn't tell me where he gets it.
Lastly, fibreglass is plastic, that is it will deform under stress. The sag that you observe is the result. However, this process can be reversed. I use something like this in the winter, when snow load might deform my roof:
Name:	Roof Support Jack.JPG
https://www.princessauto.com/en/45-t...t/PA0008822124
The upside of this is that if you support your roof over the winter, (or any extended period of time where you aren't using your trailer) then the roof could just stay that way when not supported. At least that's what happend when I did it.
The answer to your original question, I would just use Bondo™ resin, or go to your local fibreglass place and see what they have. However, wbullivant has a point about how quickly it sets. You only have about 10 minutes to work. Lower temperatures would give you a bit more time. Have everything cut and ready to go, before you mix in the hardener.
Old 05-05-2022, 04:00 PM   #7
MI
I'm sorry, but this is just not acceptable. I won't be doing this.
I am familiar with this. However, I do have a 4x8 sheet of 3/8" thick MDO board that I might be able to use.
Scamp also strengthens their roofs so they are ready if you want to install an AC unit. The call it "Prep for A/C" in their Standard Features. I am just guessing but I think they just add more glass from the chopper gun. Maybe they add a piece of wafer board in there too.
Attachment 145794
I was already thinking along the same lines and bought one.
I was all set to just use my boat building fiberglass materials but then the comment about them not adhering to polyester gave me pause. That was good info. I will just switch to a polyester resin for the wetting out. It is cheaper than epoxy but it smells worse and it is not as strong.
Old 05-05-2022, 04:26 PM   #8
Actually, it is the other way around. The epoxy bonds to polyester resin just fine. However, polyester resin may not bond to the epoxy.
Old 05-05-2022, 04:32 PM   #9
MI
Thanks, that brings me back to my original plan. I just need to get some micro balloon filler material for my epoxy resin.
Old 05-05-2022, 04:40 PM   #10
MI
Woo Hoo! I just found my other box of supplies. I think I have everything on hand to do this repair.
Now we will see if the weather cooperates.
eco
Polyester or Epoxy. Can you tell just by looking? Icefish Care and Feeding of Molded Fiberglass Trailers 15 10-20-2020 07:54 AM
Fibreglass Filler Recommendations. sonny75 Problem Solving | Owners Helping Owners 2 07-31-2020 10:12 AM
Water filler and cord access Gary Z Care and Feeding of Molded Fiberglass Trailers 3 03-30-2009 12:50 PM
Bed, tire cover & filler shirley munson Classified Archives 18 06-01-2006 01:57 PM
propane bottle filler Legacy Posts Care and Feeding of Molded Fiberglass Trailers 20 02-07-2003 06:01 PM
