Originally Posted by R_ROTTON
You are both awesome!!! Found the bolt configuration in the manual too!! One more question...do you know anything about the front door hinges? They look good, but both are cracked in one place. Can they be repaired?
Depends; the hinges are refrigeration hinges by polar mfg. co. My originals were cast brass which can be brazed. they are Polar #402 and are not available. They make a diecast chrome plated model 102. I replaced mine with Polar #412 Stainless steel which are pricey. you want 0 offset. I got mine through a HVAC supply company that deals with refigeration equipment also. you have to look at their catalogs to tell them what to order. Now it is your lucky day if you want my old pair with my modified hinge pins.
I have just finished my mods for the year and was going to post used parts on the forum, hinges being one item. I was going to ask $10 for the pair plus shipping and will throw in some stainless steel bolts and nylon lock nuts. not enough for the complete rehab but you can get washers and the rest at Lowes. for $5 more I will throw in about 6 or 7 elevator bolts and 4 black plugs that fit into the inside of the door to hide the bolts. This assumes that the doors on the CT are the same as The VT tip to tip on the hinges is about 7".
Michael J
